Carbureted turbo setup?
Old Jan 15, 2013 | 05:15 PM
Bman1320's Avatar
Car: 1986 Camaro Z28
Engine: 5.7 Carburated
Hey all, I've been thinking about turbocharging my car. I guess my biggest question is about carburetors. Is it possible to have a suck through setup on a turbocharged engine? If so, how and where would you mount it?
Old Jan 15, 2013 | 05:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Carbureted turbo setup?
Not sure about suck thru, most if not all carb setups i have seen have been blow thru. I am not a carb guy tho
Old Jan 15, 2013 | 05:37 PM
Twin_Turbo's Avatar
check out a turbo trans am or formula, pontiac 301 from the late 2nd gen
Also, martin turbosystems, accel turbosonic...draw through. Not the greatest systems but they do work
Old Jan 15, 2013 | 05:38 PM
Bman1320's Avatar
What are some of the disadvantages of the draw through vs. blow through?
Old Jan 15, 2013 | 06:40 PM
project89's Avatar
crappy mileage, no intercooler ,less power and none of the new school turbos have the correct seal on the compressor side to be used in a draw application
the only way to do it really would be one of the old martin or acell systems which do pop up on ebay from time to time
Old Jan 15, 2013 | 07:26 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Blow thru is alot more common and proven.
Advantages of blow thru is it makes alot of hp, no need for intercooler on under 10psi builds with aluminum heads. Alot of parts and info available.
Commin disadvantages, be very good at and or learn to very good at diagnosing and tuning carbs. Higher fuel consumption. Alot of owner input for the tuning.
A good friend of mine runs mid 9s in a street driven ls swap fox body. It gets the job done.
But he is collecting parts to switch to efi to turn it up more and make more efficient.
Old Jan 15, 2013 | 10:24 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Swing over to the turbo forums. Theres a ton of info for blow-thru carbs...
Old Jan 16, 2013 | 08:24 AM
Bman1320's Avatar
What all would you have to do to convert a draw through carburetor to a blow through?
86Firebird86
Dec 26, 2015 07:21 AM
BDR
Nov 7, 2015 03:05 PM
Zane Story
Oct 8, 2015 12:40 PM
customblackbird
Oct 1, 2015 04:30 PM
Doobie52
Sep 11, 2015 06:19 PM
