oil feed and return?
Old Feb 25, 2013 | 12:52 PM
  #51
project89's Avatar
Re: oil feed and return?
Originally Posted by SiCkRs
Oh ok do they have to be torqued to a certain spec?
also to do it right the feed has to be up and return has to be straight pointing down correct?
there may be tq specs for them but i just tighten all mine with a wrench , i pretty much snug them real well and never had an issue.
the feed/drain can be stright up and down, but anything upto 15* off vertical is fine
Old Feb 25, 2013 | 01:39 PM
  #52
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
oh ok i will do that today
also today i raised up the car and found out he has the oil feed in the oil pan should i just run it like that?
Old Feb 25, 2013 | 03:27 PM
  #53
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
ls oil pans have a location above the filter for pressure feed.
Return can go back to oil pan or timing cover.
I prefer timing cover return. Easier to swap out timing covers than tapping pan.
I prefer to not tap pan with it still on the car. I just dont want to chance aluminum shavings tearing up anything.
Old Feb 25, 2013 | 03:34 PM
  #54
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh ok well the oil pan i have has a an fitting right above the oil sensor or whatver that thing is in the side of the oil pan i aint sure if this is a good feed or not because when i started the car it did not shoot oil out of it.
Old Feb 28, 2013 | 01:05 AM
  #55
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
http://vtsql.gkvbf.servertrust.com/L...ck-p/cbr02.htm
ok well since i dont have a tap would you guys recommend me this caught my attention since it has two port just incase for another turbo haha.
Old Mar 12, 2013 | 05:55 PM
  #56
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
ok well i bolted up the turbo today i have a question how would i turn the center piece to have the oil feed facing up since right now its side ways
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
gta892000
Sep 16, 2015 12:37 AM
