We can all learn from this.
Old Mar 10, 2013 | 08:53 AM
  #51
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: We can all learn from this.
Originally Posted by TraviZ
You run pcv? do you feed it back into the intake tube? I just ran two hoses from my valve covers into a catch can. I hope my new Napier rings help control oil consumption with my wider gap this time around.
I'm running a ford powerstroke vac pump to my valve cover PCV. It draws vac full time.
Brakes are hydroboost. Only vac lines running out of my intake is for the FPR, Gauge, and BOV.
This system I think is the best combination for a blown motor.
-- Joe
Old Mar 18, 2013 | 03:52 PM
  #52
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
-- Joe
What CFM can the Ford PSD vac pump pull?
Old Mar 18, 2013 | 05:20 PM
  #53
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Not a clue. I can measure actual vac, but no way to know the CFM.
-- Joe
Old Mar 21, 2013 | 12:31 AM
  #54
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Yes! Vacuum pump, Exhaust gas evac, PCV, whatever it takes to get crankcase vacuum.
2.
Looking at the picture at the top of the thread I want to say a hard object bounced around quite a bit. Very unlikely to detonate "sort of" on one or two cylinders, unless it was a fuel distribution issue, such as a drop in fuel pressure in the middle of the fuel rail or something that caused uneven air fuel ratios across different cylinders. How does the OTHER side look?
3.
I Believed the reason for the loose second ring is to prevent any pressure from building between the top and second ring- to keep them from squeezing the top of the piston apart. On my roots blown 355 I file fit a traditional set of rings (the $100 federal mogul file fits) to .026 and .028 respectively. Boost was only 10psi max so a stock ring gap probably would have worked as well. (as low at .018"). I think the more important aspect is the piston/wall clearance, the expansion of the aluminum alloy. In other words, good machine work per application. A street car should run a tighter piston wall, a tighter ring gap, in general- because issues like blow-by, oil quality, and cylinder wall wear are dramatically affected by those two factors. (not to mention bearing clearance). And PCV! Even if your valve cover doesnt smoke, you need PCV because all combustion engines produce some blow-by, and getting rid of it quickly helps keep the engine clean.
Old Mar 21, 2013 | 11:48 AM
  #55
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
The other side had damage as well which at first I thought it was spark plug chunks but really it seems to have been pieces of piston from that Cylinder #3 explosion. I have been running a hose from each valve cover to a catch can with a breather. This should be sufficient for letting oil gas escape correct?
Old Mar 28, 2013 | 07:33 AM
  #56
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Got some work accomplished yesterday.
Gunner242
Dec 25, 2015 04:49 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jlanz55
Sep 29, 2015 08:55 AM
3.8TransAM
Sep 27, 2015 08:37 PM
mfp189
Sep 27, 2015 09:25 AM
