88 Iroc Turbo Build
Old Mar 23, 2013 | 04:21 PM
cdawg's Avatar
88 Iroc Turbo Build
Alrighty, i'm working on getting all my parts for my car.
story: traded it for a 92 honda hatchback, i bought it with a slipping transmission and a dead hole, so i bought a rebuild kit and did the transmission my self, and did a compression test and found it had a bent valve.
now i'm putting everything back together, i've got a 355 after i tore it apart flat tops, not sure on rods but im sure everything else is stock, cant get that lucky.
now i am going to boost the car since i've got everything back together.
parts i have
Walbro255, just got it the other day
DSM 450CC injectors, low IMP.
set of rollers/ not sure which brand/ no names
Holset HX50 T4 Turbocharger. 1000CFM .
Small FMIC, from my hondas(not sure if i can make it work or not.)
Random intercooling pipeing( Alot of it)
Knock off BOV (EBAY)
Knock Off 55MM Wastegate 7 psi spring can be changed.
AEM Wide Band.
Moats Burn2
Moats eprom Simulator
3 bar map.
Things to buy
Headers - Thinking about using s10 headers and flipping them upside down? ( opinions are welcome)
ECM 749 - edit: Just bought the ECM
Tuning software.
anything left out please let me know so i can get the rest of my item bought, and i will take pictures as i go.
Old Mar 23, 2013 | 04:25 PM
cdawg's Avatar
Re: 88 Iroc Turbo Build
also does anyone make a cheater direct plug and play harness for the 749?
Old Mar 24, 2013 | 11:28 AM
cdawg's Avatar
damn 108 view no responses i must be doing good!
Old Mar 24, 2013 | 11:41 AM
83 Crossfire TA's Avatar
The Parts list is reasonable. Is the hx50 Off of something Or is it aftermarket?
You can repin the harness plug. What is your plan with tuning?
Old Mar 24, 2013 | 12:14 PM
cdawg's Avatar
plan on using code59 software, the holset came off a 11L M11 Cummins Box Truck, i can re-pin the harness just wondering if anyone out there is making plug and play harness's yet, maybe ill attempt one?
Old Mar 24, 2013 | 12:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
730 speed density harness basically works fine, just needs few pins moved. Not many and I forget which ones, but I believe it was something to do with the low imp injector drivers. Ppl say to swap IAC stuff but I didnt have to on my 730 ecm control code 59 and it worked fine as far as I could tell, but i was using a ls1 iac
You could use any MAF harness but theres more repin work required and need to add another ecm pin connector. Not hard just time consuming. Follow the diagrams
Old Mar 24, 2013 | 01:21 PM
cdawg's Avatar
what do you all think of the s10 headers upside down? only down fall i see with most others that go under the oilpan that would heat up the oil pretty quickly...
Old Mar 24, 2013 | 08:30 PM
cdawg's Avatar
any ideas on the s10 headers? i'm gunna order them up monday or put a post for the WTB turbo headers no responses by Monday ill order up the s10's
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
