Which of these cams would you choose?
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
75-100 shot of nitrous
10-15lbs of boost
Stealth ram intake
3.73 gears/auto/3200 stall
dart iron eagle SS heads
street strip but mostly strip
COMP CAMS:
Cam 1: 236/248 113
Cam 2: 230/236 113
Cam 3: 230/244 112
Cam 4: 242/248 113
Cam 5: 224/230 112
Cam 6: 224/236 113
Cam 7: 227/234 112
10-15lbs of boost
Stealth ram intake
COMP CAMS:
Cam 1: 236/248 113
Cam 2: 230/236 113
Cam 3: 230/244 112
Cam 4: 242/248 113
Cam 5: 224/230 112
Cam 6: 224/236 113
Cam 7: 227/234 112
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Which of these cams would you choose?
What motor? Stock L98 shortblock? What kind of power adder? Blower or turbo?
Car: 1987 IROC-Z
Engine: 6.2L
Car: 89 Iroc-z
Transmission: TH400
Way too big imo. I run near that duration in my 400. I would have gone cam 6 but you dont give much info on the cams to really determine things.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I would have went with Cam 3: 230/244 112. Lots of SC intake air and N2O air needs lots of exhaust duration to dump the waste.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm running the following cam on a 413" sbc with P1SC and AFR210s
224/236 @ 0.050 276/288 adv .535/.554 lift 113lsa 108ctr
(which I assume is cam6 in your list)
Good idle, doesn't sound like crap, low end power off boost, etc.
-- Joe
-- Joe
