ZZ3 Turbo Iroc - Round Three
Old Mar 2, 2014 | 08:15 AM
  #551
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: ZZ3 Turbo Iroc - Round Three
Wooo! Good to see some positive progress. Dont sell it!
Old Mar 2, 2014 | 01:58 PM
  #552
Capt. P's Avatar
Car: 90 Formula Firebird WS6
Engine: 305 TBI
Glad it's going good. You are due some good numbers my friend!!!
Old Mar 2, 2014 | 05:43 PM
  #553
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
gone
Old Mar 2, 2014 | 05:51 PM
  #554
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Replace the injectors.
Old Mar 2, 2014 | 07:36 PM
  #555
DIGGLER's Avatar
im thinking 5psi wouldnt make enough difference to make it lean like that... i did calculations awhile back on swapping some injector sizes and it took a boatload of pressure difference to make a 24# injector flow the same as a 26# injector. might be something to try out yourself? (calculate the flow difference 5-7psi would make)
is the gauge fluctuation a fluke? maybe it actually is the injectors crapping out once they get hot?
Old Mar 2, 2014 | 07:54 PM
  #556
project89's Avatar
i think u have an injector or 2 hanging open causing the fuel presure loss ,causing a false lean condition
if it was truley lean it would have poped in the intake
to high of a fuel presure can also make the injector hang open
intake pop = lean
ex pop = dead rich
contact southbay fuel inectors and see if they will bench test ur current injectors , they can throw them on the flow bench and hold at a high duty cycle and see if they mess up
Old Mar 2, 2014 | 07:56 PM
  #557
project89's Avatar
if ur running ms 2 extra u can test urself since it has an injector test function but u would have to rig up a bench with a supply of solvent or water to the injectors , do not use something flammable
Old Mar 2, 2014 | 08:01 PM
  #558
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 2, 2014 | 08:05 PM
  #559
DIGGLER's Avatar
intake pop = lean
ex pop = dead rich
project may have nailed it with the injector hanging open. that makes perfect sense. if these injectors are high impedance, i would go to a low impedance, since you have the megasquirt. (although i dont remember if you have to change jumpers to run low impedance injectors?)
Old Mar 2, 2014 | 08:07 PM
  #560
project89's Avatar
with ms u change a few settings in the tune to enable the use of low -z injectors, if these settings are not spot on u will have issues.
i have prescision turbo low-z injectors in mine and until i tweaked my injector settings ( ones in the manual did not work for these injectors) i had some wierd fueling issues
personally i would stay away from low-z inectors , they have uncoverd an issue with the pcb design that when low-z injectors are in use may cause some electrical noise in other circuts for some ppl
in the future i will be swaping my ms out for an ems pro ecm or ms pro ecm
Old Mar 2, 2014 | 09:03 PM
  #561
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Depens on which board he used. I use the Microsquirt module for mine, and it doesn't have PWM injector control.
-- Joe
Old Mar 2, 2014 | 09:18 PM
  #562
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
With the available high imp inj out today i dont see an advantage or need for low z inj
Old Mar 2, 2014 | 09:39 PM
  #563
DIGGLER's Avatar
i would think the faster acting low impedance injectors would make for a better idle/driveability? didnt he have a set of 65's or roundabouts? not a necessity, but if you have the ability to run them....
Old Mar 2, 2014 | 09:42 PM
  #564
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats what i've heard but i have 127's that are turned down to 105 at 40 psi and no issues. Didnt have issue with siemens 80's either. So i'm not convinced in low z for anything unless it makes a difference over 127-160+ lbs hr
Old Mar 2, 2014 | 10:18 PM
  #565
Drac0nic's Avatar
Very interesting theory. If you had 60s at 80% dc you would be at roughly 240 lph. At 100% you would breech 300. The question at that point becomes firmware bug holding injectors open vs injectors experiencing an issue. Know anyone with a portable oscope? May not be a bad idea to just check that. But then agai. Where are the super rich symptoms if that is the case?
Old Mar 2, 2014 | 10:31 PM
  #566
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Maybe Im wrong, but if an injector or two hung open, wouldn't only THOSE cylinders go rich while all the rest went lean as the pressure dropped?
Old Mar 3, 2014 | 12:50 AM
  #567
project89's Avatar
this is true u would get any cyls with a hung injector flooded with fuel , and the others may not get any fuel depending on what remians for fuel presure
Old Mar 3, 2014 | 04:32 AM
  #568
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It depends on the injector firing strategy chosen.
Are you firing your injectors once every two crank revolutions? If so, and you have your latency spot on you probably have duty cycles the injectors can deal with at idle.
Right now my 42# injectors are firing 4 times per cycle (two crank revolutions), which makes for very smooth part throttle and throttle transitions, and it even idles. However when I switch to the 50s, the idle pw would be too short and it would go erratic.
The MS also has EAE with lag compensation, which changes the way the injectors fire under certain conditions.
http://msextra.com/doc/ms2extra/MS2-...anual.html#EAE
-- Joe
Old Mar 3, 2014 | 04:50 AM
  #569
project89's Avatar
granted i have low-z injectors but i basically had a stock 250hp sbc with the tpi and turbos ontop of it it idled just fine on the 85# injectors
ae enrichment took a while to get right since it only needed very small values , but other then that it acted like it had a set of 24's in it
Old Mar 3, 2014 | 07:15 AM
  #570
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 3, 2014 | 08:14 AM
  #571
project89's Avatar
problem is i dont think u will be in the lean condition long enough to make a difference between the primary tubes
if u could rig up some sort of supply to the fuel rail with no flamable fluid u could run the injector test on ms and hold them at a high pulse with and visually see what the injectors do while they spray in the air , i would build a test rig that allows u to control the presure in the rail and do the test while fluctuacting the presure inside ur normal operating range
i understand the pita about the injectors with the tpi but im starting to think it needs to be done , i cant see 2 different pumps being bad , but u are loosing fuel presure , i think u can definatly rule out the pumps , last thing in line to check is the injectors
ms could be holding the injectors open for some reason but i highly doubt it
Old Mar 3, 2014 | 08:20 AM
  #572
project89's Avatar
whens the last time u ohmed all the injectors, i would ohm them cold and after driving around, if the ohms are dropping to low when it gets hot ms wont be able to control them correctly
Old Mar 3, 2014 | 08:31 AM
  #573
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well same ones were used with stock batch fire $59 and then sequential efi via ls1 411 ecm
Old Mar 3, 2014 | 03:17 PM
  #574
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Why not do what Kyle86 did to test out his injectors? Doesn't look all that difficult to do.
https://www.thirdgen.org/forums/post...8-post119.html
One more link.
https://www.thirdgen.org/forums/post...1-post120.html
Old Mar 3, 2014 | 03:35 PM
  #575
DIGGLER's Avatar
one possible scenario- make sure every piece in the fuel system is identical to turboedtpi's setup, order a new set of injectors, and sell the ones you take out.
i just had a set of 85lb. injectors cleaned and tested. it was $100 for that, and 2 of them are kaput. (they sat in a box for 7-8 years and corroded internally) i have to give the owner a call tonight to see what he wants to do, but i think i want to get a set of 120lb. so we can run it on e85.
Old Mar 4, 2014 | 09:57 PM
  #576
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 4, 2014 | 10:49 PM
  #577
Car: 1992 Camaro RS
Not super relevant to the thread, but there's a political push to drop the ethanol subsidies and requirements right now. You might want to be careful about building a car for ethanol unless you're willing to pay race gas prices for it.
http://www.feinstein.senate.gov/publ...d-0636b31ca9cd
Old Mar 5, 2014 | 05:38 AM
  #578
DIGGLER's Avatar
Thanks for the heads up! The car already has enough fuel system to run either fuel though, so he's in good shape on it.
Steve, any idea what all could be different between your fuel system and turboedtpis car? The only thing the a/c would do is add more heat to the engine and fuel rails.... which brings us back to heat. Lol
Old Mar 5, 2014 | 06:46 AM
  #579
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
What does the log say about the injector pulsewidths when this lean out happens
Old Mar 5, 2014 | 11:36 AM
  #580
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Hey ZZ3Astro... Just wanna chime in...
Im not super tuner or anything like that. I only have forced induction experience (first hand) on Diesels, my GTP, a buddies old GN, and old MKIII Supra, an old Talon I used to own and a few other friends cars that I have worked on...
Watching your video, your fuel pressure took a minor crap right before it popped. I have seen this before. My GTP did it when the fuel pump crapped and started losing pressure under boost. It developed a nasty stumble pop under boost. I hooked up a gauge like you did and sure enough... fuel pump.
My buddies old GN did the same thing. Fuel pressure would rise, then fall... POP and all kinds of KR on his scanmaster. Replaced fuel pump and wala!
My old talon... same thing
Friend's old Supra... Same thing
I honestly dont think your fuel pump is keeping up. Can someone else watch the video and see if Im losing my mind? LOL!
Now again, im not some super boosted car tuner or anything (I did just buy HP Tuners Pro for my "future" project and my GTP) but I do have 10+ years shop experience. I think its your fuel delivery system. Pump, lines...
Just my opinion and just trying to help...
Old Mar 5, 2014 | 07:49 PM
  #581
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 5, 2014 | 08:00 PM
  #582
DIGGLER's Avatar
does it only do it in turns? check u-joints, too.
Old Mar 5, 2014 | 08:28 PM
  #583
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 5, 2014 | 08:50 PM
  #584
JAYDUBB's Avatar
Car: 1991 Camaro RS
Dont give up...
Old Mar 5, 2014 | 10:28 PM
  #585
Drac0nic's Avatar
My advice is pop the tail shaft off. If it's the bushing in the tail shaft (My brother's LT-1 Camaro had it happen) you'd just need to pop a new pushing in and drive it. At worse a tail shaft (he didn't catch it in time, had to do the tail shaft.) Shoot, I've got one here I'd send you for post if that is the case.
Old Mar 7, 2014 | 01:00 AM
  #586
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 7, 2014 | 05:33 AM
  #587
DIGGLER's Avatar
Originally Posted by ZZ3Astro
So it turns out the problem part is a simple spring pack that doesn't see any real stress from more power. An $8 reverse input drum spring pack. The c-clip pushed the flange back through itself 90 degrees, cutting a ring of the flange off and finally all the way through the pack. Kind of a weak design. I do believe this was a new part in the build 3.5 years ago.
The third gear clutches have been getting too hot. This explains or results from the third gear shift flare I get when running more than 16 psi. We installed a thicker shim to reduce pack play about .020" so maybe it will buy some more life for the clutches. The first gear clutches looked a little abused but in good working order.
All heavy duty hardware looked in great shape. Surprised the problem was something so simple and unrelated to the power the car is making for the most part. All this transmission really needs after 3.5 years is a new clutch pack for third to be in perfect shape.
My wallet, on the other hand, is going to hurt. I basically made a phone call at 4pm to a friend's shop. At midnight the front pump was all that was left to having the transmission back together. Should be back on the road by lunchtime tomorrow. I will have to pay for this level of service but I want it in Friday Fest tomorrow night!
[img]
You got that knocked out!! Good job! Will be worth the expense to have some fun.
Old Mar 7, 2014 | 10:41 AM
  #588
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
That is great you took it apart to see what was going wrong. What 3rd clutch is in it? BorgWarner Hi-E 8 disc or did ya go 9 disc? Is that .020 wet or dry? That is on the tight side. What is the 3 and 4 separator plate holes drilled to?
3/4 clutch is tough to make last with that much hp/tq.
Pulling the rear section to clean or just doing the fix to the reverse drum?
Great job getting it done.
Old Mar 7, 2014 | 02:41 PM
  #589
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 7, 2014 | 02:50 PM
  #590
Guest
Guest
Posts: n/a
D3mn.....OP should probly have went with a centrifical blower.
-also, time for a 9" or a 12 bolt.
Old Mar 7, 2014 | 03:00 PM
  #591
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah i agree. Throw it on the back burner for awhile. That car has been a nightmare, time to day dream for awhile and then get back to it once the itch needs scratched again
Old Mar 7, 2014 | 03:21 PM
  #592
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
it IS boating season again after all ^^
Old Mar 7, 2014 | 04:24 PM
  #593
Car: 1992 Camaro RS
I took a step away from my car for nearly a year after two separate engine builds took a dump on me before I ever got it a block away from my house.
When I finally got it back together it was worth the wait and it was a better car than I could have made it the first time around.
I wouldn't sell it, but working on it any more at this point is going to make you hate the car forever. These things are too much fun when they're working to let yourself ruin the experience. Put some Z-rod in it(corrosion inhibitors), some fuel preservative, put it on jackstands, and come back to it later.
Old Mar 7, 2014 | 04:39 PM
  #594
DIGGLER's Avatar
yup. let it marinate for a bit.
Old Mar 7, 2014 | 05:38 PM
  #595
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 7, 2014 | 05:48 PM
  #596
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Mar 7, 2014 | 05:53 PM
  #597
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Steve, others professing to have seen so and so, or they know so and so, who are running the stock trans and rear with a ten second car is just hearsay and speculation, and if someone does, it doesn't last too long. The reality is, you built yourself one heck of car, and had many many runs, and you should be very proud of that. Essentially stock parts with an upgrade thrown at them here and there should not be expected to live behind the power your making. I mean seriously, I hate to sound like that guy, but what did you expect? There is a guy on the buick boards who trashed several "built" 200R4's with his ten second GN during one season, and he finally just said screw it and went Turbo 400. It's a very expensive hobby if you want it to last punching it as many times as we do...
Old Mar 7, 2014 | 07:40 PM
  #598
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Welcome to the poweradder world. You wanna go 100+ in the 1/8 with a heavier car you kinda need beefy stuff.
Now i ran my car hard for 2 years on a 10 bolt into the 9's and dozen 10 sec passes but i dont think i beat on my car as hard as you do lol.
Dont worry about the th400 weight or the 9". It wont slow you down that much. You'll make the power once the fuel issues leave you alone. Else put on a better intake like single plane and i honestly think it will pick up a ton.
Leave it sit for abit
Old Mar 7, 2014 | 09:21 PM
  #599
DIGGLER's Avatar
i feel strange having a good 3.23 9 bolt in my backyard as i type this. lol
could you post up a timeslip again? couldnt really expect much more, considering it had a stock rear, a 700r4, a tpi intake, factory type heads, and was full weight with stock suspension.
Old Mar 7, 2014 | 09:33 PM
  #600
DIGGLER's Avatar
engine- change intake to single plane/miniram/hsr/etc.
swap heads to 195+ afr/trickflow/brodix etc
20psi boost
twin 255's, -8 feed, -6 return, regulator
trans- th400/good converter setup for turbo
rear- 12 bolt/9" with 3.08-3.23ish gears (still good for cruising)
suspension- lca's, relocation brackets, decent torque arm
i bet the car would touch 9's with just these items at the same weight, still look the same, and still be a good driver.
