remote mount turbo for 87the l98 and mass air?
Old Aug 15, 2013 | 07:55 PM
m grasso's Avatar
Hey all. I am in the proses of building a remote mout turbo. I have most of my parts list and will be starting the build in the next week ir so when i take my car off the road. I need to know what i can or cant do with my mass air sensor. I will be running a stock turbo off an 05 cummins because of the similar displacement. I plan at running only about 4psi to start. And maby get up to 10the psi max with a tune and msd. I have everything figured out but the mass air if i have to re pin for speed density thats fine but would like some insight. Thanks Mic.
Old Aug 15, 2013 | 10:44 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: remote mount turbo for 87the l98 and mass air?
Subscribed.
Old Aug 16, 2013 | 07:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You probably will max out the sensor with a few pounds of boost. Once you do that only way to add fuel is pe vs rpm and turbos arent really linear in boost vs rpm so i doubt it will work well.
So you can add an fmu to help with fueling, or possibly look into blowerworks maf upgrade which supposively works on stock ecm but allows it to read 600hp or more of airflow, or you can repin to speed density and run boosted code like code $59.
Its up to you
Old Aug 16, 2013 | 07:36 AM
m grasso's Avatar
Ok thanks for the info ... is that ecm coad one for a syclone/typhoon? I read somthing about that.
Old Aug 16, 2013 | 07:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup. Code59.org i think is still around. Loads of info there
Old Aug 16, 2013 | 08:04 AM
m grasso's Avatar
Ok i will check out that sight i think that might be the way to go. I want to get this done in a reasonable time frame and i will be on a tight budget when work gets slow... gotta love that, bust my a$$ to make money but dont have the time to play then winter comes and i have all the time in the world but dont have two nickels to rub together. Lol
Old Aug 16, 2013 | 08:54 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Its pretty easy swap. Need to repin harness for 730 ecm and add a 2-3 bar map sensor. Buy a 730 ecm and memcal, chip adapter from moates to do the new chips. Download the files from code59.org or possibly ask around for a v8 starter bin.
Old Nov 30, 2013 | 06:56 PM
formulakeith's Avatar
Car: subaru wagon, two formula's
Engine: tpi 350's
Transmission: 700 r4
Axle/Gears: 3.27 posi
Did this project ever get done? I'm about to do a twin turbo on my 89TPI and I'm looking to see whats out there
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
