Twins!
Old Nov 22, 2013 | 12:45 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Twins!
Christmas came early!!!!
Twin Borg Warner S366's 0.91AR
Going on a 400ci SBC
- Dart block
- Callies crank and rods
- Custom diamond pistons (10:1 SCR)
- Xceldyne belt drive
- LJMS custom solid roller
- CFE/BMF 248cc 18* heads
- Ferrea Comp Plus intake valves
- Ferrea Super Alloy exhaust valves
- PSI valve sprigns
- Xceldyne Ti retainers
- T&D shaft mounted rockers
- Edelbrock 2950 intake modified for injector bungs
- Elbow w/ 90mm throttle body
- Drysump
- Powerglide
Old Nov 23, 2013 | 08:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Twins!
Should be fun! just made a 1018 on my setup, very similar to yours. If you can get that LIL M block, you'll want it for safety factor lol
Old Nov 24, 2013 | 02:46 AM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
im going SHP, if it fails it a good excuse to build another
Old Nov 24, 2013 | 12:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Twins!
Lol i dont wanna build anymore i want this to live as long as possible
Old Nov 27, 2013 | 12:37 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Well... Things took a turn for the awesome yesterday. picked up a set of CFE/BMF 18 degree heads. this thing should make some pretty killer power now...
Might need a lower profile elbow to clear the hood....
Xceldyne belt drive.
new camshaft from Lil John Motorsports Solutions
Should sound pretty badass through dual 4" downpipes dumped under the fenders
And some shiny bit's to match the new paint.
Old Dec 6, 2013 | 04:00 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
More parts...
New transmission specialties Reid case powerglide
B&M pro bandit stealth shifter
T&D shaft mounted rockers for the 18 degree heads
Old Dec 30, 2013 | 09:39 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Axle/Gears: Strange S60, 4.10s
Re: Twins!
Was wondering what you were up to when the 383 went up for sale.
Look forward to seeing this setup being built. That elbow has to go though, not only is it too high, it is fugly. I know YOU can do better.
Old Jan 13, 2014 | 04:36 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Dont Worry... I have a nice custom billet intake surprise coming my way.
Old Feb 7, 2014 | 05:04 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Custom pistons are here from Diamond for my new engine! 2618 Material, inboard pin boss design, 0.927" x 2.25" x 0.225" H-13 tool steel pin, Hard anodized.
strange double adjustable shocks also arrived.
Old Feb 13, 2014 | 08:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Twins!
Pretty pistons
Old Feb 13, 2014 | 09:51 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: Twins!
Very stout build.
What do you expect out of the combo w those turbos. Full trim? I know you got a full trim planned out for that monster.
I have an op to get a few of the exact same turbos. But hesitant to use em on my build.
Old Feb 14, 2014 | 02:10 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
***** to the wall, turbos max'd out it should make 1500-1600hp. It wont see that often though. For now atleast....
Old Feb 14, 2014 | 08:26 PM
Car: 02 SS
Re: Twins!
Sounds good to me. I built my Ls motor to about equivalent'ish as yours.
Looking into getting a pair for mine.
What all are u gonna use to get that beast to hook and run as strait as possible.
Looks like we have similar builds. I even got same hood. 4in
Old May 9, 2014 | 05:55 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Exhaust springs on, Rockers and pushrods installed, pushrods are a Trend 3/8" 0.135" wall 7.00" effective length. Valves set, plugs gapped. Basically ready to set into the car.
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Moved the car into its new home which is much closer to me.
Had the cage certified to run 8.50's
Got the new rear gears installed and the rear end back together and ready to go under the car.
Front bumper and chin spoiler ready to go to paint.
Been working on a bunch of the little stuff in the car.
- Parachute handle
- ECM mount
- Window net
- Meth tank and pump
- CO2 bottle mount
Old May 9, 2014 | 05:56 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Installed the engine and trans in the car.
Modified the 700r4 transmission crossmember for the the powerglide.
Car: 1979 Malibu
Engine: Blown LSx
Re: Twins!
Update.... wiring and more wiring...
everything is soldered and heatshrink, but butt connectors anywhere. may not be the nicest but there was a lot of wiring to run and tie together between the EFI, gauges, digital shift light, fuel pump controller, meth system, Holley EFI, Boost leash boost controller/pulse leash combo, transbrake, neutral safety etc... while still keeping the lights and whatnot fully functional. The Holley EFI has internal datalogging which has been tied into a input on the ECM so I can trigger it when driving. Both gauge panels were wired on weatherpack connectors so they can be easily removed.
Dash back in.
Boost controller fired up.
Powered up the car, set the inputs/outputs for the various functions, configured the parameters for igntion and uploaded a rough tune to fire the car once the time comes.
LS-3 coils mounted, along with the dipstick, vacuum manifold, various relay etc....
ZZ3Astro
Aug 13, 2019 12:57 AM
86Firebird86
Dec 26, 2015 07:21 AM
1992Z28!
Nov 19, 2015 07:33 AM
Macchinist
Oct 2, 2015 02:55 PM
customblackbird
Oct 1, 2015 04:30 PM
