Intercooler mounting. Need pics and ideas.
Old Dec 25, 2013 | 07:47 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
K so I'm running twin turbos with a front mount intercooler. I'm torn between running a 91-92 front bumper and a 86-90 front bumper. I was hoping somebody had pics of intercoolers mounted with either bumper and how you were able to get air through it efficiently.
Old Dec 26, 2013 | 11:19 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Intercooler mounting. Need pics and ideas.
I have a 91-92 nose, but this mount will work for any 82-92 Fbody nose
Remove the AC condenser and notch out the side supports to clear the tubing. The radiator will lean towards the engine some. A filler panel is needed to hold the rad and the stock hold down in place. Piece of cake to route the tubing, excellent airflow to both IC and rad, stock mount of fans
Old Dec 27, 2013 | 10:27 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I have a '92 bird and I wanted to keep A/C and all the amenities, so I had to get a little creative with my IC mounting and plumbing. One downside was that I was a little limited in intercooler sizing. I mounted my intercooler horizontally between the core support and the front bumper bar. It is in front of the factory air dam so air will flow through the intercooler and then through the condenser and radiator in the same fashion that the factory intended.
The turbo sits in the right side battery tray area in this setup (single turbo setup vs your twins). The charge piping runs right down to the IC and then from the IC up inside the left front fender, over the battery (relocated to the left side and scooted closer to the radiator than the factory tray places it).
So far it has worked well for me. I may install some small fans on the intercooler at some point so that I can draw air across it when I'm in the staging lanes at the track, but I don't run it at the track very often hahaha!
-Paul
Old Dec 28, 2013 | 01:16 AM
Interesting mounting Quad. I wonder how much air gets directed through th radiator and not pushed under the car?? Maybe hook up a NOS spray bar infrint of the cooler and spray it just before you leave.
Old Dec 28, 2013 | 09:30 AM
quadgoat's Avatar
Car: 1992 Firebird
Roughly the same amount of air that is diverted to the radiator in a totally stock setup I expect. Running down the road the car runs as cool (or cooler) than it did before the turbo setup. It will get a little warmer in traffic with the A/C on than it did before (220 is the highest I've seen iirc). I've got dual fans from an LT-1 f-body mounted up with a Be Cool aluminum radiator. I'm sure the intercooler blocks a little airflow, but it doesn't seem to do much harm. The 'birds are completely "bottom feeders" in that they get virtually all their cooling air from underneath the vehicle since there isn't much for airflow through the front bumper. This can make cooling system engineering/upgrades challenging lol!
-Paul
Old Dec 30, 2013 | 07:45 PM
How do you feel about using a 91-92 firebird nose and mounting one inter cooler in each opening?
Twin turbos twin inter coolers.
Old Dec 30, 2013 | 08:49 PM
quadgoat's Avatar
Car: 1992 Firebird
Interesting idea. Would it be possible to use a large enough intercooler in those locations to be effective?
Old Dec 30, 2013 | 09:07 PM
I would hope so. Intercoolers looking at would be 2 12x18x3 2.5" in/out
Old Dec 30, 2013 | 09:19 PM
quadgoat's Avatar
Car: 1992 Firebird
Ok, my question pertained to the (relatively) small openings in the bumper, which are also partially obstructed by the turn signals (as well as possibly fog lights in some applications). That's all.
Old Dec 30, 2013 | 09:29 PM
Ahhh I see. I wouldn't be using fog lights or turn signals and would modify the bumper support or leave it out.
Old Dec 30, 2013 | 09:37 PM
quadgoat's Avatar
Car: 1992 Firebird
Gotcha, didn't realize it was a race car haha. In that case I don't see why it wouldn't work!
Old Dec 30, 2013 | 09:52 PM
Race car?? Naahhhh. Weekend warrior not a daily driver though. Gettin stupid on street tires.
Old Jan 5, 2014 | 03:04 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
im going to be using the 2 'fog light' holes on the camaro to duct air through the intercooler then make a new cover to take the air out through the hood.
Old Jan 5, 2014 | 06:11 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
If your going to go through that much trouble to install the a2a why not step up to air to water, and add a heat exchanger in your water plumbing
Old Jan 5, 2014 | 07:04 AM
Twin_Turbo's Avatar
I did that, an A2W, completely bolt in, no holes drilled anywehere. uses all factory bolt locations, fits under stock hood.
Old Jan 9, 2014 | 11:29 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I really love that setup. I kinda wish I had done that on mine.
-- Joe
Old Jan 9, 2014 | 11:56 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Twin_Turbo, can you describe how effective the A2W setup is once the car is heat soaked (think steady state) on a 85*F day? I'm wondering how it does once the water is hot, and how effective a water cooler (heat exhanger) is.
Old Jan 9, 2014 | 01:25 PM
Twin_Turbo's Avatar
Haven't driven much still working on the car but no heat soak issues yet. The pump runs @ low speed all the time and goes full speed by an rpm activated switch and a hobbs switch (whichever comes in first), I have a big stack cooler under the front. the IC is always cool to the touch. It certainly keeps IATs lower than the flat mounted procharger solution.
Old Jan 23, 2014 | 11:37 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Size:  38.5 KBHere is mine. I took out the crash bar. It's a procharger 950 hp air/air unit.
Old Jan 23, 2014 | 01:33 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I use a 85-89 bumper with the center cut out. I also cut the center out of the grill so it gets the most air.
Old Jan 23, 2014 | 01:54 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Sorry I didn't realize you were asking about the Pontiacs.
Old Jan 23, 2014 | 02:12 PM
Damn I wish I could use a big center opened grill like camaro.
I'm thinking about using this bumper now.
Old Jan 24, 2014 | 01:55 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Some picture ideas for intercooling TA's
First two pics where from one of my very first setups.
The third is my current setup. The hood also has reverse scoops to remove hot air fast from the radiator and IC.
BTW: I think I still have those grills somewhere.
Attached Thumbnails Intercooler mounting. Need pics and ideas.-front-engine-1.jpg   Intercooler mounting. Need pics and ideas.-fmi.jpg   Intercooler mounting. Need pics and ideas.-suspension-components-paint-upgrade
Old Jan 24, 2014 | 01:57 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Reverse scoops shown on hood.
Attached Thumbnails Intercooler mounting. Need pics and ideas.-eco-track-solo-1.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
gt4373
Sep 9, 2015 10:29 AM
