pcv system for forced induction?
Old Feb 12, 2014 | 11:24 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
What is everyone running? I just had my pcv venting to atm. It's there a better way?
Old Feb 12, 2014 | 11:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: pcv system for forced induction?
You'd need to run a very strong check valve to make sure it doesnt pressurize crankcase. I havent looked for one but i hear they exist. Vented valve covers to catch can works great but for part throttle a pcv is desired.
Other way is to run cover to air intake to your turbo or charger if you have an intake tube with filter. Theres always some vacuum there. Need a air oil separator inline tho to prevent spraying down the wheel with oil
Old Feb 12, 2014 | 03:27 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I see external vacuum pumps recommended for big cam and boosted applications but I've never seen anyone mention them. Anyone use one? Primary use would be to keep brake booster powered but with catch can and/or filter sounds like they could be used for pcv use.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
aharvel50
Sep 21, 2015 07:31 PM
CatmanFS
Sep 19, 2015 09:00 AM
