91 5 speed turbo build
Hello all I have been lurking around here for the last couple months while I have been fixing up my car getting it ready for the street. Here is a little back story on the car I had a 91 rs 305 5 speed hard top in high school and have had a thing for them ever since and about two months ago when I came across a car identical to the one I had in high school except it was a t top car came across craigslist for $700 I had to have it. It had been sitting in a garage for 9 years so the fuel pump had gone bad and the front breaks were dragging really bad. I got a couple buddies and we drug it up on the trailer and got it home I did some reading up on changing the fuel pump and decided to cut the access panel.
This is what it looked like when I got it home
After many hours of cleaning and detailing
Went to the local u pull it junk yard and scored a nice dash pad and a few missing interior pieces.
I had to pull apart the dash and replace a few bulbs that were burned out unfortunately I have to pull it all back out and fix the circuit board
Here is the old 305 I got the smog pump and AC off I need to order a AC delete box.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 91 5 speed turbo build
That's the same header I used, although I cut mine up into about 8 pieces and re-worked it. But that was mainly because of my AFR heads.
Looks like you don't have plug problems with that engine like I did.
-- Joe
-- Joe
Terrell351
Jun 13, 2021 01:13 PM
bjpotter
Jan 22, 2019 12:27 PM
