Air fuel ratio affected by air pump
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Hi
I have a 305 tpi with paxton sn2000. Everthing stock except for injectors and full exhaust with air tubes on headers.
I am assuming the air pump will give an articially lean afr based on the air being pumped in. I am not sure what percentage of air is from pump and what percentage is from cylinders.
Is this being to detailed or will the air pump have an impact
I think the paxton can deliver 850 cfm
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Air fuel ratio affected by air pump
I think it switches pumping air to the cat after warm up. Do you have a Wideband 02 sensor somewhere in there?
I am installing a stand alone wide band downstream of narrow band in cat area to help with tuning (innovate mtx wideband afr meter)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The AIR pump doesn't put air into the exhaust upstream of the O2 sensor during closed-loop operation.
Car: 89 GTA
Just keep it away from the cat and you should be good. Also, before the switch to closed loop your afr will be off like you were thinking.
Car: 83Z28 HO
Transmission: G Force 5 speed
Actually, that's a good question. I'd think whenever the air pump is discharging to the manifold tubes, the sensor will see the added air and it'll go slightly rich. Should have no effect when it shifts to the CAT....assuming it's shifting as it should...
If anyone can confirm that would be great
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
The O2 sensor will NOT be accurate while pumping unmetered O2 into the exhaust upstream from the sensor (manifold), so this is cut off once the computer wants to use the O2 sensor.
The air pumped into the cat makes the 3-way converter more efficient. This will have no effect on the O2 sensor since it is downstream.
I cannot say with authority whether the O2 sensor is used during PE mode. I tend to think not.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
