My 355ci twin 66mm turbo setup is running!!
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Damn I can't believe I haven't been on here that long.....my last login was in 2012 lol. Anyway, I've been busy putting together my twin turbo setup and its done and on the road, only running 8psi with a blowthrough e85 carb. Took it to the track last sat and my best run was a 11.44 @ 128mph on 8psi with a HORRID 2.2 60ft, converter has to be loosened up....won't even go to 3k on the tbrake so I was just rolling out off the footbrake, no boost shifting at 5800. Converter is coming out this week and back to Andre at edgeracing to loosen it up to around 3600ish....it starts making boost around 34-3500rpms.
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: My 355ci twin 66mm turbo setup is running!!
congrats man, I saw the video on mhtg, now you gotta get some videos of the track days!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Congrats! Werent you building a 400" shp tho?
Thats pretty stout times for being in colorado!
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Nice man, congrates. Looks really promising.
Whats up Justin? been a while! that shp shortblock is covered up on the engine stand as we speak, all it needs is a set of heads. I just freshened up the 355 with new bearings, rings and rod bolts seen that motor already has heads lol....but they'd be a little small for the shp 400". I was surprised by the mph up here @ 5200+ft elevation too! once it gets moving, it goes but gotta get this converter sorted out, waayy too damn tight...good for mph going down the track but horrible of the line lol
Car: 89 Iroc-z
Transmission: TH400
Yeah my buddy's 400" or so lsx went 135 on 7 psi down here at 1200 ft on good gas. Thought that was impressive but you arent to far off and much less cubes and heads
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Aug 13, 2015 08:28 PM
