Trans cooler w/ intercooled car
Old May 5, 2014 | 09:57 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You guys with automatics. Where did you mount your trans cooler? I almost put it infront of the intercooler last night, but then realize it would probably heat the charge back up in the IC.
I'm tempted to put it out by the rear bumper but not sure if that would be a great idea on a long cruise.
-- Joe
Old May 5, 2014 | 10:31 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Trans cooler w/ intercooled car
My intercooler is between the crash bar between frame rails. I got about 10-11" from rad to intercooler.
I put the trans cooler on rad and have my oil cooler on intercooler lol
Old May 5, 2014 | 11:54 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm. Got a picture? I'm having a tough time visualizing.
-- Joe
Old May 5, 2014 | 01:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Dont have any online i can attach. Have to upload one later tonight. Intercooler sits where fog lights use to so big gap between itercooler and radiator. Basically i stuff 2 coolers in between. One for trans one for motor oil
Old May 5, 2014 | 04:01 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I had mine under the car beneath the battery area mounted horizontal with a high power ~8"electric fan-was there for about 17yrs,but a few years ago remounted it to RH battery tray area since I had relocated the battery to the back-this time vertical and at an angle so it can pull air from the opening ahead of the wheelwell.With a ~7x11"1.5"thick"stacked plate" radiator core,works great with my mild 350/2400 stall converter-I like to keep fluid~180-200*.It's plumbed in with -6 braided line.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
roysatikas
Sep 22, 2015 08:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
