AFR Results with Supercharged engine
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Hi,
I went for a road test today and recorded my rpm and afr with the following results (during acceleration)
RPM AFR
1000 15
1500 14.5
2500 11
3000 11
3500 10
4000 10
4500 10
5000 11
During deceleration I am between 14-16 afr from 3000 to 1000 rpm
My engine 5.0 tpi, Paxton sc, full exhaust (headers and catback), water/meth injection, tune up everything else stock.
I was planning on switching to 30# injectors and new prom from tuned performance. The injectors and prom are sitting in my basement waiting to be installed
Do I need to make the switch?
RPM AFR
1000 15
1500 14.5
2500 11
3000 11
3500 10
4000 10
4500 10
5000 11
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: AFR Results with Supercharged engine
Id say "Switch" out the LB9 and the ball driven snail blower.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
looks like your a tad rich, what are the boost #'s at those rpm/afr numbers?
doesn't look like you need to upgrade injectors
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
At this point you are more than rich enough.
Do you have more specifics on your AFR numbers(decimal points) and boost levels?
IF anything you could lean it out slightly with less fuel pressure(or less meth), BUT you are surely safe at this point.
Nuff NUff and 86Z thank you for the intelligent replies (as opposed to the other).
my boost levels measured last fall (I am assuming I am a little lower now since I have installed headers this spring)
3000rpm 3psi
3500rpm 4.1 psi
4000rpm 5.2 psi
4500rpm 6.3 psi
5000rpm 7.54 psi
I will measure boost later today (max boost 6.82psi @5200rpm- change from stock manifold to dyno don headers)
I have a progressive water/meth (50/50) controller on at 2psi. Injection rates are 2.1gph @3psi, 6.4 gph @5psi, 10gph@ 7psi
PS. My son was reading the afr gauge while I was recording the rpm so it was difficult to get exact decimals
3000rpm 3psi
3500rpm 4.1 psi
4000rpm 5.2 psi
4500rpm 6.3 psi
5000rpm 7.54 psi
Car: 1987 Iroc
Axle/Gears: 3.50 9"
No problem! That's what the site is for!
What is your timing? stock? If so, I'd keep it as is and ride on.
The only other option I'd even consider would be to put in the 30 lb injectors and remove the meth(mine picked up by removing meth and upping the injector duty cycle), but then you'd have to get the chip tuned to compensate for the richness you're gaining by having the meth on the car(more headaches)
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by toronto formula
I was planning on switching to 30# injectors and new prom from tuned performance. The injectors and prom are sitting in my basement waiting to be installed...
Car: 1986 Camaro SC
with those boost levels, and a stock bottom end i would stay around mid 11.0-11.5 afr levels to keep the cylinders cool.
i'm running meth and 42lb injectors, i shoot for 11.3 - 11.5 afr range at 14#'s
they make all different size nozzles for meth
toronto formula
Nov 10, 2015 06:17 AM
