power adders: questions
Old Sep 21, 2014 | 11:15 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
So i'm looking for more power out of my corvette L98. Right now i'm thinking either a turbo set up or a procharger. I'm torn 50/50 between the two because the pros and cons make them dead even. For instance, fitment wise, a turbo set up requires a decent amount of fabrication whereas the procharger is a direct bolt on kit. However, financially, I can get a twin turbo kit from CXracing for $1500 compared to over $5000 for a procharger. If i found a procharger complete kit used for the right price i would pick it up.
So this is my preliminary question: Procharger or Turbo?
HP goal is 500.
Also, my apologies if this has been discussed already. I've been reading turbo threads for the last few hours and i'm full of questions. I'm the kind of guy who weighs all the aspects before going ahead with anything. Thank you!
Old Sep 21, 2014 | 11:45 PM
Clayton91's Avatar
Car: 1989 Camaro IROC-Z
Engine: LTx 305
Axle/Gears: stock w/2.73 :(
Re: power adders: questions
Im going to guess that's a at the crank goal?
Old Sep 22, 2014 | 05:41 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What turbo kit are you looking at from cxracing?
I don't know that the single turbo header will work with the 113 heads without some cutting and rewelding. I know my AFR heads had issues on #8 and #6.
-- Joe
Old Sep 22, 2014 | 09:49 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
HP goal is 500...
I'm also running a Corvette, but its a '96 w/LT1. I was running a D1SC Procharger for awhile, but that was yanked because I was close to selling the car w/out it. In my opinion, skip the D series, and consider getting an F series Procharger w/the correct pulley for your goal. Turbo's in a C4, although are very doable, are just too much trouble to even bother with, unless you go rear mount, and if you do get an aero charger (self contained turbo)...
http://aerocharger.com/
Old Sep 22, 2014 | 09:59 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't think he owns a Corvette. I think he has a Corvette L98 in his thirdgen.
-- Joe
Old Sep 22, 2014 | 10:06 AM
-- Joe
Your definitely right Joe, I just now took a glance at his profile to confirm.
If it's going in a 3rd gen, then go turbo and don't look back...
Old Sep 22, 2014 | 10:20 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yep. Turbo thirdgen is cool stuff.
-- Joe
Old Sep 22, 2014 | 11:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
To get a crx "kit" to work you'll have tons of time in it and end up spending alot on small parts to get it to work. If you cant fab yourself skip the turbo idea.
500 hp is doable with the blowers. Could find used vortech kits here under 2, and sone prochargers here under 3.5-4g. Not bad. D1 procharger is a great blower. Even the small p1 or whatever could get you near that power. D1 can do 800 hp, no need for anything bigger
Old Sep 22, 2014 | 01:07 PM
GTAman's Avatar
Wow a lot of responses already! Thanks everyone! I do not have a corvette, just an engine from one ha ha good enough! Anyway, I would like to see 500 hp at the wheels. My main influence is the Trans am GTA "Firefox" experimental car Gm toyed around with back in the day. Sounds like there's a lot of votes for turbo here! I've read quite a few threads this far and saw a LOT of fabrication going on. Unfortunately, I do not have welding experience and the equipment for fabrication of that magnitude. I know there are no die t bolt on kits or else everyone would've bought a kit and have a turbo car by now. Also, for tuning, I still need to get my EBL ECM. Please give me your thoughts! Thank you!
Old Sep 22, 2014 | 01:28 PM
I am running the EBL-P4, I am extremely impressed with it. Turbo headers are very easy to fabricate, if you can get your hands on a used Edelbrock shorty header setup (headers and y-pipe), then fabricating a single turbo system will be a breeze. That is how I did mine. If you need any help with fabricating or tuning let me know, I'm in Jerzey too...
Old Sep 22, 2014 | 01:37 PM
GTAman's Avatar
Lethal i though I remembered you. I've been following your thread for a long time! Is the p4 the one based off the 7730 ECM? I remember emailing them and I remember them saying not to get the flash model because I have the older ECM and I have MAF. I have hedman shorties and y pipe on the car now. Not sure if that helps or not. I have to go over your thread and make notes. Thanks!
Old Sep 22, 2014 | 01:43 PM
Yes, we would just need to do a few repins to the harness (takes a minute) then the EBL Flash will hook right up to the stock connectors. Very very easy hookup, as Rbob made everything a breeze to do. The Hedman shorty headers are perfect, just figure out what turbo you want to run (preferably T4), then get yourself a T4 flange on ebay. The welding is the easy part, just need to line everything up beforehand. While you have the headers off, that is the best time to get that oil return fitting in the oil pan. Don't use the block off plate for the mechanical fuel pump as the return, as at high oil pressures it will cause a back up, and its better you just return it to the oil pan directly...
GTAman's Avatar
Correction: bob told me the EBL flash would be the best bet for me. He said the p4 would need a total repinning.
Old Sep 22, 2014 | 01:49 PM
Yes, the differences between the two are minimal in terms of features, but since your terminal connectors are different under the dash leading to the ECM from the stock harness in comparison with the 7730, the EBL Flash is definitely the way to go. If you need any help at all just say the word...
Old Sep 22, 2014 | 03:08 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If you go turbo, make your manifolds out of mild steel.
Mine are chopped up and re-welded XS-power stainless headers. Even with a tig, my welding on stainless looks like a turd. Unless you weld stainless regularly, just do mild.
-- Joe
Old Sep 26, 2014 | 10:23 PM
GTAman's Avatar
Hey Guys,
So i just got around to reading the whole thread thouroughly and it seems Turbo is the way to go. It looks like i will be looking into welding classes so i can do quality fab work to fit 2 mean hair driers. i've seen some pics so far and looks like the best way (aesthetically and functionally) is to place them where the battery and the Charcoal canister goes (behind each headlight).
Questions: How big should i go on fuel injectors? also, due to tight spaces, has anyone experimented with oval exhaust tubing for the down pipes?
Old Sep 27, 2014 | 05:37 AM
project89's Avatar
Hey Guys,
i have all the materials except header flanges to build a set of twin turbo log headers if ur interested , i can sell u the materials or make u a set of headers
i also have a setup of up and fowards that are 85% complete if u wanted to use those for a twin or single setup, i would use them for a single gt45 setup though that will get u to 500 crank hp easily
Old Sep 27, 2014 | 08:19 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
BBS is selling Turbo kits... I got a single turbo header, crossover pipe and driver's header for about $900 I think... I got the option to keep my AC (Live in Florida / Black Firebird)... TurboTPI was making 570 rwp with his single turbo BBS header...
EBL P4 here too...
As for the ATI price / power, I would go turbo too...
Old Sep 27, 2014 | 08:08 PM
GTAman's Avatar
Thanks everyone!
So i did some math to size up my fuel injectors for this project, using a formula i got from accel, and for 500 hp i should be using 47 lb injectors. That sound about right?
Old Oct 6, 2014 | 10:22 AM
... assuming a BSFC of around .65, and an 80% duty cycle, you will want to run 50lb injectors at a minimum for 500-FWHP. If we're talking RWHP, you will want to run 60lb injectors.
Old Oct 6, 2014 | 10:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup just find some 60lb siemens. Relatively cheap and work fantastic
Old Oct 6, 2014 | 10:52 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why are we concerned about going over 80% 'duty cycle' on modern injectors?
-- Joe
Old Oct 6, 2014 | 11:04 AM
I still try to utilize 80% as a range due to any slight increase in boost pressure that the user wasn't ready or prepared for, from either boost creep, or a flawed boost control system, as it will allow for the user to cover additional kpa if need be. Call it added insurance...
Old Oct 6, 2014 | 11:17 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I guess. I've had more problems dealing with oversized injectors at idle than I've had running out of fuel up top.
I realize that some of the OE injectors would get erratic at higher duty cycles, but any modern injectors will work properly even static as long as your software is compensating for open and close time.
Running static will of course lead to issues when you suddenly need more fuel, but I've run mid 90% for over a decade with no issues
-- Joe
Old Oct 6, 2014 | 11:38 AM
86trbota's Avatar
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
If you decide to build your own kit it is well worth the time and effort. I have about $700 into my whole hotside, headers crossover and downpipe. That includes welding and paint and wrap. I bought header flanges and a open wheel header kit from jegs and started cutting. One thing i have learned is do NOT cheap out the first time it will cost you in the end.
Old Oct 6, 2014 | 04:40 PM
DIGGLER's Avatar
i built a set like that a long time ago but never used them. when i got finished i realized i had used 18ga. tubing and figured that would never hold up.
Old Oct 6, 2014 | 06:37 PM
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
I bet they would have done ok for a while as long as they dont rust and good bracing. Mine is 16g and only the headers were aluminized i hope it lasts for a while!
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
