Some may think I'm going crazy, what do you think?
Old Jul 11, 2015 | 10:05 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Ok, here is the thing.
My turbocharged GTA's engine finally went down and it did swinging. After 25+ years of service, un openned, 100% stock, it decided to finally let go...It was about god d@mn time!
So now I am in the process of FINALLY start the buildup on the new 388 I've had in an engine stand waiting for the time for current engine to die, and the time came.
But now I find myself in an akward indesision; to spend a fortune and build the new engine with the extremly little time I have or ditch the hole turbo and assemble just a mild block and simply enjoy my ride. I do know one thing; I need something flashy under the hood, so I was thinking ditching the HSR aswell and get me one of these;
Or these:
The question is; has someone had one of those installed? How is the sound they make down the straight? How much HP should I expect from one of these with a mild bottom end and mild heads or ported stock heads?
Please be gentle with your comments, I'm in a delicate state of mind😜 Jajaja
This is my current setup:
Old Jul 11, 2015 | 10:26 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Some may think I'm going crazy, what do you think?
I will let everyone reading along know that jajajaja is hahahaha...
Stick with the turbo, you'll be lost without it during every stop light, as well as the highway. What happened to the stock engine? Head gasket, or blown piston/rod...?
Old Jul 11, 2015 | 10:59 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Honestly dont know, engine detonated while WOT at the main straight and then oil blow by everywhere. While doing a check up plugs had were oil soaked, but engine was running "fine", but as soon as I started the engine again oil reached the cylinders fast, almost on all if not on all cylinders. My guess is that all the piston rings are gone.
I do not drag race this car, I only Solo1 and road race it.
Old Jul 11, 2015 | 04:44 PM
project89's Avatar
i have future plans to ditch my hsr as well and use that second intake pictured , except i will be using it witht he turbo setup , i will build a custom plenum for it
i found it on ebay for 499$ i posted a link in the chinesse hsr thread
Old Jul 11, 2015 | 05:52 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Wickedly cool looking!
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
