Who wants some turbo parts?
Old Dec 20, 2001 | 01:03 AM
GMI FAST's Avatar
Here's my stuff for sale:
Holley Dominator EFI-converted tunnel ram for SBC $400 w/rails
TWM 75mm throttle bodies w/2 extra injector ports and rails $250 each
Spearco T3-flanged cast iron twin-turbo manifolds $500
Old Dec 20, 2001 | 01:06 AM
GMI FAST's Avatar
Bungs need welding to finish:
Old Dec 20, 2001 | 01:09 AM
GMI FAST's Avatar
Dope throttle bodies:
Old Dec 20, 2001 | 01:12 AM
GMI FAST's Avatar
I was duplicating this setup to the last detail. Same manifold and 75mm tb's were used:
Old Dec 20, 2001 | 02:25 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Wheres the pics of the turbo manifolds ?????? Need pics please
Old Dec 20, 2001 | 08:12 AM
GMI FAST's Avatar
I will take some this weekend. They are similiar to the old Banks manifolds.
Old Dec 20, 2001 | 05:31 PM
Bobalos's Avatar
I thought you were back in the game?
BW
Old Dec 20, 2001 | 05:59 PM
GMI FAST's Avatar
Never left the game. In fact, I've never been more involved. Check sig...
Old Dec 20, 2001 | 10:33 PM
Bobalos's Avatar
So what's the story with the 87 TA? 455 with TT...... wow? where did that come from? did you buy it done?
BW
Old Dec 20, 2001 | 11:36 PM
GMI FAST's Avatar
The 455" is out of my old 1972 GTO. I haven't decided if I will use it. I may use a 1969 4-bolt 428" block out of an old Bonneville I stripped many years ago.
I am currently converting a Doug Nash Warrior tunnel ram to EFI, and I have sold my 72# injectors to buy some 83# units. I am running Eagle rods and a stock nodular iron crank w/billet main caps. I have had the heads laying around for a while. They are left over from an older project car. They have been fully race-ported and have completed reshaped combustion chambers. The camshaft is a custom Ultradyne hydraulic roller w/turbo specs. I have some headers mocked up, and might finish TIG-welding them this winter. Turbos are good to go! I am running the new Accel/DFI Gen 7.0 unit w/wideband O2. The intercooler is the same unit as built for my recent SBC turbo car, but we have changed endtanks and added 3" outlets instead of the previous 2.5" units. Throttle bodies are Holley billet 75mm units. Same fuel system from last car: 2 S/X pumps w/ -8AN lines, single -8AN return line. Trans is a TH400 w/reverse pattern, brake, and Art Carr 4000 stall converter. Exhaust is 3" stainless downpipes in to a single 4" Spintech muffler. I will be running the same Spohn suspension as the last car, with the exception of the tubular K-member, 4-cylinder swaybars, and Koni drag shocks.
I have done the Poncho-in-to-3rd gen swap before, and this will be a breeze due to the motor plate we are using instead of old 2nd gen T/A stock mounts.
Old Dec 21, 2001 | 07:46 AM
Guido's Avatar
Car: 2000 Trans Am
Hey Dan, why dont you take some photos ofo your mocked up headers this weekend while you are getting some of those manifolds too! Id like to see some of what youhave going on!
Old Dec 21, 2001 | 08:27 AM
GMI FAST's Avatar
You bet, my boost-happy brother!
Old Dec 21, 2001 | 10:19 PM
Bobalos's Avatar
Right on amigo. do you have the linkage to connect the two TB's? do the TB's use the standard GM TPS?
BW
Old Dec 21, 2001 | 10:46 PM
GMI FAST's Avatar
Unfortunately, I do not have the linkage for the throttle bodies. We weren't sure how the throttle bodies would fit on my plenum, so we didn't order any linkage in case we had to make our own. The linkage can still be purchased from TWM. The standard GM TPS is used.
Old Dec 22, 2001 | 10:43 PM
Earl 87gta's Avatar
GMI Fast lett me know if you ever want to get rid of that 428 I have a 68 fire bird and I have ben looking for one to put in it.
Old Dec 24, 2001 | 12:29 AM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Good *** GMI, you got some bad *** rides
Old Dec 24, 2001 | 12:33 AM
GMI FAST's Avatar
Thanks, dude!
32 and I feel like 18. You can never go too fast, young Jedi.
I am thinking of ditching the Supra for a 1995 R33 Skyline V-spec. I found one in Australia for $25,000 US. It costs $17,000 to make it US-legal, but whatever!
Old Dec 24, 2001 | 09:58 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have seen a similar set up where the builder opted for putting the Throttle bodies on each side of the plenum instead of in front for a race (nonintercooled) system, also you list this: Holley Dominator EFI-converted tunnel ram for SBC $400 w/rails
Spearco T3-flanged cast iron twin-turbo manifolds $500 My question is, does or did "spearco make cast iron exhaust manifolds?
Old Dec 25, 2001 | 12:36 AM
GMI FAST's Avatar
Yes, they did. Their old company logo is cast in to the side of each manifold...
Old Dec 25, 2001 | 12:40 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
any pictures of those manifolds yet?
Old Jan 22, 2002 | 05:02 AM
82resto's Avatar
Do you still have those manifolds for sale?
Jon
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
