350 tpi . Cam and Nitrous.
Old Nov 8, 2015 | 01:34 AM
Iroc_Lopez28's Avatar
Car: 1988 IrocZ
I'm planning on doing a 350 tpi swap where my 305 tpi used to lay. I wanted to know what would be a good cam to use if I was planning on using nitrous? Everything else will stay stock except for the cam (obviously) rockers and springs. Any suggestions? I'll also be running a SuperRam intake instead of the stock TPI intake.
Old Nov 9, 2015 | 03:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 350 tpi . Cam and Nitrous.
Any good na cam will work with small shots 200 and under.
Old Nov 9, 2015 | 08:44 PM
Car: 1988 IrocZ
Any good NA cams you would recommend? I'm looking for a semi streetable set up
Old Nov 9, 2015 | 08:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Stock head deal if modded heads for more lift, and screw in studs i would not go any larger than comp 276hr stuff, 224/230 on a 110-112 or equivalent
A 269hr 218/224 is also a good milder cam with good power on something like that
Will need computer tuned
Old Nov 9, 2015 | 09:05 PM
Car: 1988 IrocZ
Cool . Both will work with 1.6 rockers? And will both need a computer tune?
Old Nov 9, 2015 | 09:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah can run themwith 1.6's but heads will need to be setup for higher valve lift than .470-.480 ish. Guide bosses need machined down and studs need pinned or machined for screw in. Then need a valvespring around 130lb seat/350-370 lb open or so
Old Nov 10, 2015 | 06:51 PM
Car: 1988 IrocZ
Would that be a hydraulic roller or a hydraulic flat tappet?
Old Nov 10, 2015 | 06:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Depends on the motor. Is it a roller block? Your current 5.0 is a roller and you can swap over the roller components if your 350 block is a factory L98 roller block
Old Nov 10, 2015 | 06:54 PM
Car: 1988 IrocZ
Yeah. It's a 5.0 out of 88 Iroc and the 350 will be out of a 92 Z28
Fishy4Life
Oct 29, 2015 07:25 AM
321GO!
Oct 27, 2015 08:16 PM
transamaster
Oct 21, 2015 03:04 AM
SRKLEGIN
Oct 19, 2015 07:27 PM
eddie99
Oct 15, 2015 02:47 AM
