Procharger question/ install help. asap
Old Dec 24, 2001 | 06:57 PM
88IROCZ350's Avatar
Happy holidays everyone.
1. I am currently installing my p600B supercharger on my 88 camaro. I got to the part where i put the crank pulley and spacer on. Well it all went alright until i put the spacer on the old crank pulley, i put the balancer bolt up there and tried to get it started but come to find out the damn thing is too short. It says nothing about needing a new bolt in the instructions and there is no longer bolt for it, what do i do? i took my balancer off last winter to put my cam in, did it not get pushed back on far enough? or whats the deal here, i'm confused. Thanks for the help
question 2
I was looking at the directions, and i saw that i have to cut my fuel line for the fmu. Is there any way that i can get around this so i don't have to hack it up incase i ever go back and not use the fmu? thanks for the help too.
Old Dec 24, 2001 | 07:09 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
call procharger there is supposed to be a 4 longer bolts
Old Dec 24, 2001 | 08:14 PM
zz4z28's Avatar
Yes, you do need a longer bolt.
Mine came in the kit, I'm sure if you call ATI they will send you a new one.
I think mine was only a half inch to an inch longer.
Old Dec 24, 2001 | 09:32 PM
88IROCZ350's Avatar
thanks a bunch guys, maybe it feel out of the package, i'll check in the box, it did have a small hole in it. What do u guys think about the fmu lines? should i just ask ati about those too?
Old Dec 24, 2001 | 09:40 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
see my reply to that quetion on your 12psi/injector size "thread" on this board
dutch930
Sep 11, 2015 06:58 AM
red90IROCls1
Aug 25, 2015 06:56 AM
IROCZ1989
Aug 19, 2015 08:15 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
sonu1975
Aug 11, 2015 08:38 AM
