Can someone measure a Vortech bracket?
Old Aug 24, 2017 | 10:18 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On the Carb SBC setup that some of you have, I need to know how far out the cast bracket is that bolts the plate to the head. I know there is .360" spacers used behind it for serpentine vs vbelt, I just need to know how far out that bracket is. (not including the .360" spacers).
If someone could measure their bracket I'd appreciate it
-- Joe
Old Aug 24, 2017 | 11:06 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Can someone measure a Vortech bracket?
Joe, either give SuperChargersOnline a call, or Summit Racing Tech, as both offer the replacement bracket for the Vortech Carb SBC and can more than likely give you the exact specifications of it...
- Rob
Old Aug 25, 2017 | 04:38 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I called a few places, even vortech. Nobody would measure it.
I ended up just doing the math - measuring the balancer face to the pulley end, then head to balancer face. I came up with 4.75" from head to blower mounting plate. Hope it's right.
I swapped the 6" crank pulley for an 8", and upgrading the bracket to a double plate design. Should make stupid boost and hopefully not throw belts.
-- Joe
Old Aug 28, 2017 | 10:33 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
So your looking for the front of the cylinder head to the inside edge of the bracket? give me a bit
Old Aug 28, 2017 | 12:30 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thanks Dan. I appreciate it.
-- Joe
Old Aug 28, 2017 | 03:01 PM
Car: 86' IROC
Axle/Gears: 3.45
My bracket is drilled out, so it sits about 1 3/4" lower to clear the hood. I cant get a straight shot off the cylinder head, but off the china wall heres what i got. I got it as close to 90* off the bracket as i could. If you need another shot lmk - i snapped that on lunch and didnt have a ton of time to take the intake tubing off
Old Aug 28, 2017 | 03:11 PM
Car: 86' IROC
Axle/Gears: 3.45
Old Aug 29, 2017 | 11:38 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It just dawned on me that the cylinder heads on a SBC are not on the same plane. The driverside head is more forward than the passenger side, so your measurement wouldn't transfer over to mine since I'm bolting mine to the passenger head.
Sorry.
I guess if I knew the distance from the BACK of the blower plate to the water pump mating surface that would be the same, as it's a machined surface. Any chance you could get that and I could double check mine?
Thanks!
-- Joe
Old Aug 29, 2017 | 11:41 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Where in mass are you ? haha
Old Aug 29, 2017 | 02:36 PM
Car: 86' IROC
Axle/Gears: 3.45
Yeah, ill see what i can do tomorrow. Its crunch time - going on vacation Thursday. I live in Rockland, 15 min south of Boston.
Old Aug 29, 2017 | 06:28 PM
Car: 86' IROC
Axle/Gears: 3.45
Unfortunately i cant get a straight shot on it. You cant see it in the picture, but the plat sticks about 1.5" farther inward that the water pump mounting surface. i would have to guess its very close to 4 1/4" from just eye balling it
