Paxton SN-92 idler pulley problem
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
Added a later post
Engine: 305 TBI
Axle/Gears: 4.10
Re: Paxton SN-92 idler pulley problem
I am the original owner of a 1991 Firebird Formula tbi with a Paxton SN-92 supercharger. The idler pulley (not the drive pulley) that came with the supercharger has failed. I can repair the pulley, but the unique bolt/shaft that connects the pulley to the plate that holds the supercharger is beyond repair.
I installed a spare pulley that I purchased years ago, but it is unavailable now.
I have searched the internet for a replacement of both the pulley and bolt/shaft combination or separate bolt/shaft, but no luck. If the pulley fails again, I wont be able to use my supercharger.
Any ideas on some kind of fix/replacement?
The pulley is 6 rib and 2-1/8" diameter.
Thanks,
305tbi
draymoore@triad.rr.com
Thanks,
305tbi
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Is it that metal pulley
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 305TBI
I installed a spare pulley that I purchased years ago, but it is unavailable now. I have searched the internet for a replacement of both the pulley and bolt/shaft combination or separate bolt/shaft, but no luck. If the pulley fails again, I wont be able to use my supercharger. Any ideas on some kind of fix/replacement? The pulley is 6 rib and 2-1/8" diameter.
They might even have another option for you.
- Rob
https://jonbondperformance.com/index...ath=10_124_298
