Turbo exhaust
Old Dec 24, 2018 | 02:29 PM
89transam500hp's Avatar
Turbo exhaust
Hey guys want to add a turbo either single or twin looking to see wwhat header you guys used for your turbos I have 8.9:1 and want do 15 psi on 92 and menthol want to make 850hp but not sure how to set up turbos with little space in engine bay I removed washer fluid tank and now have vacuum pump there for brakes and is it safe to use 50-100 shot nitrous with turbo
Old Dec 26, 2018 | 08:56 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Turbo exhaust
The ebay chinese kit actually works really well, but can be a problem with the #6 plug on some heads. I had to re-work the primary.
Making a turbo kit is very easy though. If I were to do one again, I'd do twins though. I honestly think smaller turbos with built in waste gates and 2 1/2" down pipes is a lot easier than a single turbo with external waste gate and a cross over.
-- Joe
-- Joe
Old Dec 26, 2018 | 12:54 PM
Re: Turbo exhaust
-- Joe
-- Joe
do use still use o2 sensor or do you put them on close loop
I have have sensor hooked up just no egr
Old Dec 27, 2018 | 09:25 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Turbo exhaust
I ran a wideband in the downpipe.
I didn't use a factory ECM, I have not since probably 2008 or so. All aftermarket.
-- Joe
Shinobi'sZ
Aug 23, 2017 09:44 AM
ChillPhatCat
Oct 29, 2001 10:05 AM
G92Joe
Oct 21, 2001 06:56 PM
Dan W
Aug 24, 2001 07:29 PM
91bluebird305TBI
Mar 23, 2001 01:15 PM
