Check out the new NOSzles in Hot Rod
Old Jan 8, 2002 | 05:09 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
These things are the best setup I've ever seen. The fuel injectors screw into the tops of them and the nitrous and gas mix is injected right into the cylinders directly. This is even better than direct port of the runners. They are in Hot Rod on page 59 if anyones interested. I hope they are affordable. I can't seem to find the price anywhere yet. PN is : 08008NOS For V8's
Old Jan 8, 2002 | 07:14 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
They're in the new motortrend too. It says $1500 for the kit.
Andrew
Old Jan 8, 2002 | 07:19 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
That's just for 8 nozzles and the distribution blocks? Forget it.
Old Jan 9, 2002 | 12:00 AM
89ProchargedROC's Avatar
no offense but do you guys know what a GOOD Direct Port fogger setup goes for?
and how much it is to get it installed?
obviously you DONT
$1300 is what i heard and it is a damn good price for
not having to drill holes
not having to bend hard line
its a bargain
The NOS pro shot fogger is $1000 plus you have to have it installed and bend all the line for it
Old Jan 9, 2002 | 05:39 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
No offense taken. Maybe it is a bargain compared to having one installed but still, not everyone has that kinda money to throw around. If I ever decide to take that route as opposed to my current plate system, I would be definately consider them.
Old Jan 14, 2002 | 11:45 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Talk to some people at Nitrous Xpress. They make custom kits for a lot of cars.
Old Jan 14, 2002 | 03:55 PM
RoadRacer's Avatar
Am I just going nuts or does it look to anyone else that those things would totally screw up the height of the fuel rail once they were installed? The pic in HotRod wasn't very detailed.
Don
Old Jan 15, 2002 | 02:02 AM
um....put a solid spacer washer under the bolt that goes into the intake for the fuel rail bolt
problem solved
Old Jan 15, 2002 | 06:12 PM
crazeinc's Avatar
do you have any idea how many spots I need Jimmy if you put one of those on your ride...
BADNBLK
Nov 16, 2016 09:12 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
gwade12
Aug 8, 2015 08:17 AM
