Oil drain for twins
Old Jun 10, 2019 | 01:12 PM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Oil drain for twins
I was over in TallTims twin GT35 build asking about oil feed/drain lines as I'm in the middle of a similar build. I've figured out that I can use -4AN lines off a tee from the oil pressure fitting for the feeds. As for the drains, he used two -10AN lines into the fuel pump block off plate. I have a later ('96) block so no plate. Is the oil pan my only option? Can I run a y fitting into the pan from the two lines or will that back up? Or is there enough real estate to put two 1/2" holes above the drain plug. I'd prefer not to yank the motor but... Thanks.
Here's the work in progress:
Old Jun 10, 2019 | 02:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Oil drain for twins
I dont think that would have gravity drained to a plate to begin with atleast not the driver side turbo. Maybe but not ideal
You will want to drain to oil pan, ideally one per side. Or to a scavenge pump and pump to valve cover
Old Jun 10, 2019 | 03:48 PM
brian p's Avatar
Car: 86 IROC
Thanks, So I'll scrap the idea of running a two into one y fitting into the oil pan. I can't see much room on the passenger side ( to get a drill in there) but on the drivers' side of the pan it looks OK. Maybe a 90 degree drill. Just drill, tap and thread a fitting in. Sorry, that's a question, I've tapped other thicker stuff before but nothing as thin as a pan.
Old Jun 10, 2019 | 03:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Fitting near front of pan may work with a 2 into 1 drain just make sure both are as downward an angle as possible.
I never tapped a pan lol just welded fittings
Old Jun 10, 2019 | 04:06 PM
brian p's Avatar
Car: 86 IROC
I like the welded fittings idea better but I take it that means pulling the pan...
Old Jun 11, 2019 | 06:58 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have.. It's always a mess. I found on my 412 the fuel pump blockoff plate just didn't allow it to drain fast enough so it got backed up, so I had to stick a -10 fitting in the front of the pan.
Self contained turbos would be cool. I guess the packaging would be difficult.
-- Joe
Old Jun 11, 2019 | 07:16 AM
brian p's Avatar
Car: 86 IROC
So the consensus being drill and tap at your own risk. And don't complain when it leaks... For a car that gets so little mileage, I think I'll try that route for starters with the plan to put weld in bungs next time the engine comes out. And that'll be when I get brave and turn up the boost.
Old Jun 11, 2019 | 07:26 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Don't drill. Punch your hole so it rolls the sheet metal, which gives you enough material to tap. You start with a taper punch and then finish with a straight punch that's close to the OD of the drill bit you would normally use.
I used some 'right stuff' on the threads when inserting the NPT to -10 AN adapter.
I'm not that concerned about leaks as much as I am metal getting into the oil.
-- Joe
Old Jun 11, 2019 | 07:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah i was gonna say try right stuff to seal it or epoxy
Old Jun 11, 2019 | 08:42 AM
brian p's Avatar
Car: 86 IROC
Got it, thanks for the help guys. I'll figure out all the hose and fittings I need for the feed/drains,order that, then start working on the new manual brake setup.
Brian
89FRMLA350
South West Region
Jul 30, 2002 11:55 AM
TimRS
May 13, 2002 04:55 PM
soulbounder
May 4, 2002 12:58 PM
soulbounder
May 4, 2002 11:44 AM
nblanchard
Mar 19, 2002 03:40 PM
