intercooler
Old Jan 16, 2002 | 09:22 AM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
intercooler
How does a intercooler work? Can it be used without the turbo?
Old Jan 16, 2002 | 10:11 AM
True Power's Avatar
It's basically an air-to-air radiator, that cools air instead of coolant. There are water-to-air (or is that air-to-water?) ones also. They reduce the temperature of the charged air, thus allowing you to run more boost without as big of a threat of detonation. Not sure why you would want to run one without a blower...you can use them for both turbos and superchargers though.
Old Jan 16, 2002 | 04:04 PM
maniacc's Avatar
It would be air-to-water, heat transfers from hot to cold.
the reason for running the intercooler is, when the turbo or supercharger compresses the air, it heats up to a higher than ambient temp. we all know that a engine makes more power with cold air. so the intercooler is a way of bringing that hot compressed air back down to a reasonable temp. allowing us to run more boost with a less of a chance for detenation.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
toronto formula
Nov 10, 2015 06:17 AM
Willie
Jun 13, 2001 12:24 AM
