Supercharged V6
Old Jun 21, 2021 | 02:16 PM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Supercharged V6
Hypothetically speaking, if i were to supercharge a 3.1 V6 and was planning on upgrading the camshaft as well, what type of specs should i be looking for? I know there arent exactly a ton of options for that engine which narrows down my options a lot as is. Yes, i know this would be a somewhat pointless endeavor if im looking for good cost to power ratio but im not. Thanks
Would any of these be worthwhile or not?
https://www.crower.com/camshafts.html?cat=1183
Old Jun 23, 2021 | 12:57 AM
83 Crossfire TA's Avatar
Re: Supercharged V6
Hypothetically speaking 😉
What is optimum depends on the supercharger. Centrifugal like completely different timing than positive displacement, and even different sizes, boost levels and engine compression will change things.
Oh, and people will custom make camshafts if you're willing to spend the $$$
Old Jun 23, 2021 | 05:33 AM
Car: 1982 Firebird
Engine: 2.8 N/A
Re: Supercharged V6
Thanks for the response!
Its a roots style supercharger. Do you know offhand any reputable companies that do custom camshafts? I dont mind spending the money to do it right.
Old Jun 26, 2021 | 03:00 AM
Re: Supercharged V6
Dynamically a roots style supercharger makes the engine work a lot like a bigger version of the same engine, it doesn't affect the exhaust as much as a turbo would and makes breathing on the intake easier (duh ). Barring going custom you can really choose something that has a similar or slightly shorter powerband than what you're hoping for NA, or if you're having problems getting advice going one step smaller on the intake and one step larger on the exhaust. Generally, the lower the boost the closer to an NA shaft will work well and the roots blower airflow will determine the powerband more than the camshaft so you're best not to fight the camshaft timing)
If I was choosing between the Crower camshafts that you listed it would depend on the powerband that you're looking for, the engine's compression and how much boost/which roots blower you're running.
As far as custom camshafts, pick who you like and call them. Most larger companies have some custom grind service and most smaller ones make a living off of recommending and selling custom grinds. For example, the camshaft in my "experiment" 305 which is intended for a turbocharged 305 with later modified LT1 aluminum cylinder heads is a Comp Cams grind 4-7 swap (the firing order is different than a stock SBC) ground on a billet LS style blank with a distributor timing gear pressed on it and it uses some mechanical roller lifter profiles selected to work with short travel hydraulic roller lifters. WAY more off the beaten path than what you're looking for in a 60* V6 (which has more performance parts available than you'd think because they were used in some specific dirt track and other racing).
monkeycamaro
Dec 14, 2006 08:00 AM
nightowls_gm
Aug 5, 2006 10:34 PM
wizardmasterx
Aug 3, 2005 11:26 PM
mdricken
Jul 3, 2005 01:37 AM
