Procharger carb hat recommendation
Old Jul 24, 2023 | 12:48 AM
Randyad's Avatar
I'm building an 86 IROC with a gen 1 400 stroked to 420. I am using the Holley super sniper EFI to feed it. The "carb hat" that came with the kit fits the top of the sniper but when I rotate the hat it hits the fuel lines which are slightly different when compared to a regular old 4150 dbl pumper. For reference it is the "Tallboy" cover.
To me the simplest fix is to buy a carb hat that clears the sniper fuel line placement. Any recommendations?
The less simple fix is to space underneath the hat until it clears. Roughly 1" should do it. Does anyone make such a spacer? Or will I be making one?
The least simple way would be to grind and machine the original for the needed clearance. Maybe heat it and lightly reshape it with a mallet
Thanks... And I appreciate any and all suggestions
Old Jul 24, 2023 | 08:57 PM
Randyad's Avatar
Re: Procharger carb hat recommendation
I figured this one out on my own. Turns out a carb to air cleaner spacer is a pretty common item and the Sniper is same size as any basic carb. I never even heard of one till earlier. Probably because I never had the need.
Bane
Carburetors
Jun 5, 2014 07:55 PM
RSRoboX
Carburetors
May 20, 2014 09:30 PM
madbomber824
Carburetors
Dec 9, 2009 04:00 PM
jimmy92rs
Jul 21, 2009 04:03 PM
Nebu
Carburetors
Feb 8, 2008 11:45 AM
