New Carb - Demon or Quickfuel?
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
Hi there,
in the next weeks, i'm going to buy a new carb and yank out the old holley (thrown together from 3 different carbs...).
i'm looking mainly into one of these 3 carbs
- 650 Speed Demon
- 650 Quickfuel, down-leg boosters
- 650 Quickfuel, annular boosters
Going 650cfm with electric choke, which one of these would be the best for me? downleg or annular boosters? qf or demon?
do i need a new fuel line for the qf carb because of the 4500 style fuel bowls or can i use my old one from the 4150 holley?
thanks,
nebu
- 650 Speed Demon
thanks,
nebu
Car: 91' Camaro
Engine: Carbed 305
Re: New Carb - Demon or Quickfuel?
i think i will go with the 650 quickfuel carb with annular boosters after reading the carcraft article....
but if anyone has something to add, please do so
nebu.
nebu.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I wouldn't buy demon anything
Too much casting flash left inside carbs when they leave the factory. I haven't run an annular booster carb on a motor as small as a 305, so I can't tell you if that would be a good thing or not.
Too much casting flash left inside carbs when they leave the factory. I haven't run an annular booster carb on a motor as small as a 305, so I can't tell you if that would be a good thing or not. Thread Starter
Car: 91' Camaro
Engine: Carbed 305
no one knows, which fuel line i need? the guys at summit don't answer my question i wrote them...
nebu.
nebu.
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Im in the same boat, wanting to ditch my Edel 1411 for a quickfuel, Holley HP, or mighty demon. If i have the cash, im going with the holley HP.
Car: 1984 z28 camaro / 2019 accord sport
Don't buy the demon i hate my speed demon. I almost miss the Edelbrock that I used to have on it.
Car: 87 Firebird
Engine: 5.3 76mm
I ended up getting a 82751 Holley HP DP off ebay new for like 440shipped. Im excited to get it on, and the edelbrock off
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I would not rule out a custom carb from Pro-System. They are deadly and consistent. I have had one for the last 2 years, plus his customer service is the best.... Call him anytime he will call you back...
http://www.pro-system.com/
Car: '82 Z28
Don't buy a new Demon, get a good used one if you're set on that.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
buy, carb, carberators, carbs, carburator, carburetor, carburetors, demon, fuel, good, quick, quickfuel, speed, tuning, versus
