Single Turbo Exhaust Options
Old Nov 12, 2024 | 10:09 AM
Speed Racer's Avatar
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
Has anyone successfully got single 4" pipe out of the engine bay and hooked to a single exhaust system? The crossover pipe and manifolds will take up the space between the engine and frame rails on my build, so can you go down on the inside or outside of the wheel well area? Any info would be great.
Old Nov 12, 2024 | 07:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Single Turbo Exhaust Options
Pass side with ac delete is the most available room for that but you need to make the header/manifold to work with it as it will be tight. Can oval the tubing some if needed. A tube K can free up alot more room for things
Old Nov 12, 2024 | 07:43 PM
Engine: 383
Would it run down next to the frame rail or on the fender side? Do you have to use skinny tires for clearance? If this requires cutting the body, I'll probably do something else.
Old Nov 12, 2024 | 08:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Inside frame. It may need some oval shaping to clear. Number 8 primary and the plug will need to be considered
Old Nov 13, 2024 | 10:05 AM
Engine: 383
That won't work for me. The crossover pipe from the other bank comes up thru there. I was really trying to avoid a fender-exit setup for streetability and since most tracks require mufflers now. Such is the curse of the 3rd gen- no room for anything.
Old Nov 13, 2024 | 11:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Theres room just have to design things for it. Cross over needs moved
Jordan Ruddick
Jul 22, 2024 10:14 PM
daves12secV6
Nov 10, 2006 03:48 PM
ttypecamaro
Aug 1, 2006 06:41 PM
83ho86tpi
Apr 2, 2004 06:02 PM
camaro-mayhem
Apr 28, 2002 04:17 PM
