ATI Questions
Old Jan 26, 2002 | 10:39 PM
StocRoc's Avatar
ATI Questions
First of all, I am going to get an ATI Procharger. Which ones for our cars do not have the oil lines and all that stuff, b/c that is the style I want. Also I am going to upgrade to the 3 core intercooler and get everything polished, do you think this stuff is worth the extra money?? Which kit would be best for my setup?(see sig)
Also how much boost can I run w/out blowing up my engine. It is a ZZ/4 Short block w/ world S/R Torquer heads and a Comp Cam w/ 114 degree lobe seperation, and about 9:1 compression. I can give you more info. if needed, also this will be a daily driver.
I know I can call ATI for all this, but I want to hear what you guys have to say b/c you all know your Sh*t Thanks for any help
Old Jan 27, 2002 | 02:12 PM
maniacc's Avatar
stocroc,
Any of the model that have "sc" after there model# is a self-contained unit. example P1sc or D1sc
If you go with the D1sc, the kit comes with the 3-core intercooler.
you also better be sure on your compression ratio, zz4 long blocks are normally 10:1. which is not very boost friendly.
Also you'll want to check your cam specs and make sure that you have minimal valveoverlap.
And yes i think it is definately worth the extra money to get everything polished.
later
larry
Old Jan 27, 2002 | 06:28 PM
StocRoc's Avatar
larry thanks for all the help. You answered many of my questions. As far as compression ratio the engine builder told me its about 9:1 and the cams lobe seperation is 114, isn't that pretty good for supercharging?
Thanks Again
Old Jan 28, 2002 | 03:26 PM
StocRoc's Avatar
ttt
Old Jan 28, 2002 | 04:20 PM
maniacc's Avatar
I would find out exactly what your compression, don't go on just a guess of the top of your engine builder head. the more compression that you have, the eaiser it is to blow **** up!
as far as the cam, i think you can still run a low lobe seperation as long as the valve overlap is kept to a minimum but don't quote me on that.
and yes 8:1 to 9:1 seem to be the the general concensus for a street car
later
larry
MoJoe
Sep 15, 2015 12:50 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
