NX Wet kit (20214) Install Pics..
Car: 98 Camaro SS
Transmission: M6
Just got the 20214 installed on my car (wow.. GTech'd at 11.81 on this bad boy..) and although my install looks decent, wondering what other people's looks like.... just trying to get an idea of how to dress it up a little, maybe some hidden installs, just anything really...
thanks!
thanks!
Car: 98 Camaro SS
Transmission: M6
worked L98.. running the 150 shot.
Aluminum vette heads, superram manifold base, 48mm tb, !AC !smog, chip, true ram air (clone of 1998+ boxes), LT4 hotcam, 1.6RR, fully ported/polished heads/plenum/etc, pretty much everything done to it..
and, the 20214 kit is the one that is 50-75-100-150 hp kit, although I think there is also a 35 hp setting in there too, haven't checked them..
Car: 1992 Z28
Engine: 355
What's the difference between part #20920 and part #20214? I was under the impression that NX uses a generic kit for all MPFI GM applications.
Hey GTA
what the spec on your car, I have the same kit, but I didnt want to use over 100hp jet, do you have the 150 in it?? I havent installed the kit yet but where did you installed the nozzle??? the flex tube make it hard to drill a hole in it, do you have a pix of the nozzle placement, I would appreciate it, jim
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
