need boost gauge help
Old Jan 30, 2002 | 09:51 PM
88IROCZ350's Avatar
I have completed my procharger install now and started it without any guages except fuel pressure, before i drive it i want to put my other guages in which i recieved today. My question is what is a good place i can hook the line into for the boost gauge? if u got pics or anything that would be great. I appreciate any help. I know this shouldn't be in this forum but i know many of u have boost gauges so i figured this is the best place to get a good and accurate anwser. Thanks guys
Old Jan 30, 2002 | 10:13 PM
cobrakiller1989's Avatar
my freind had a turbo charger on his civic. If my memory is correct he just hooked it up to any old vacuum line. You could try that and see if it works...just a suggestion
Old Feb 8, 2002 | 07:55 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Any Manifold vaccume line, anything above the intake will show actual vaccume, intake and below will show boost (pressure)
Old Feb 9, 2002 | 06:25 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Yep, install a T in one of the vacuum hoses that come off the rear if the plenum. Run a hose off the T to your gauge and you're set.
All of the vacuum hoses attached to the plenum or manifold base are tapped into "manifold vacuum" and will show vacuum and boost.
The only ported vacuum source on the TPI system is the one on the bottom of the throttle body. Do not tap into it. Also, do not tap into the vacuum hose going to the PCV valve
$750 L98
Feb 1, 2025 02:25 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
