Air pressure vs. Liquid pressure
Old Feb 2, 2002 | 02:09 PM
Blown WS6's Avatar
Car: 91 Formula, 92 Vert
Engine: 350 TPI, 350 LT1
Transmission: Both Auto
Ok I just bought a new pully for my blower. Its a 2.75 inch one should be good for over 12psi on my motor.
I dont have a nice interior boost gauge I'd like to have. I bought a cheap $20 Actron Vacuum gauge that also shows Fuel pump pressure in psi for positive pressure. It goes to 10 psi. I thought a pound per square inch is a pound per square inch. But it only went up to 4 psi at max rpm. I now its putting out WAY more than that because the hose piece that connects the ducting with the throttle body not only bulges out when I snap the throttle like it used to with the 3.05 inch pully, it looks like its going to freaking explode.
I took the gauge and blew on it as HARD as I could and could only get it to go to 2 psi.
Is it differant because liquids dont compresses and gases do?
Help me out here.
Old Feb 2, 2002 | 02:30 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Air gauges and liquid gauges are not interchangeable.
Old Feb 2, 2002 | 03:32 PM
Blown WS6's Avatar
Why though? Im the type that not likes to know what it is, but likes to know why it is.
I mean isnt a pound per square inch of pressure a pound of square inch of pressure whether its force is exerted by a liquid or a solid?
Its like a ton of feathers or a ton of bricks. There both a ton no matter what makes it up.
And this gauge is for air on the vacuum side and liquid on the pressure side.
Old Feb 2, 2002 | 06:30 PM
maniacc's Avatar
Make sure that the gauge that you have is reading in "In.Hg" for vacuum and "PSI" for boost.
the positive scale might be different, Example: "In.H2O" or something.
just a thought
later
larry
Old Feb 2, 2002 | 09:35 PM
Blown WS6's Avatar
No its in psi I'm sure of that.
Anyone else?
Old Feb 3, 2002 | 11:53 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
I think you summed it up when you stated cheap $20 gage. Go get a VDO 0-15 or 0-30 psi boost gage.
Old Feb 3, 2002 | 12:36 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
The boost guages from autometer can be used for engine vaccume or positive boost from a blower. In vaccume, it measures In. of HG, In boost, it measures PSI. its all included in the same guage, and the needle starts in the middle of the left, goes up for boost, down for vaccume.
Old Feb 3, 2002 | 11:58 PM
a73camaro's Avatar
You got the concept right, PSI is PSI. I would fault the gauge. Test it againts a good gauge.
People are good suckers and lousy blowers
You can suck 20" Hg, but only blow 2 psi.
Old Feb 5, 2002 | 12:28 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
wow 20" HG? i could only register 6" on my boost guage. You must be a really good sucker!
specialized
Jun 18, 2022 09:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
