Anybody with a Procharger
Old Mar 12, 2002 | 12:53 PM
KS91Z28's Avatar
I have a few questions.
1. My main pulley that the SC belt hooks up to wobbles a little. Did any of you guys have a problem with this?
2. Did you have to do any shimming to get the belt to stay in place?
3. Does ATI's installation directions suck or what?
I don't have all the bugs worked out of it yet, but I'm just thrilled it's finally in! :lala:
Old Mar 12, 2002 | 05:38 PM
maniacc's Avatar
ks91z28,
Welcome to the power adder world.
<b>
</b>
I'm assuming that your talking about the crank pulley, there should be as close to zero "wobble" that you can achieve. Make sure all your surfaces are clean and flat and that your spacer is seated properly between the blower crank pulley and the OEM crank pulley.
<b>
</b>
Yes, i has to put a .030" washer between the bracket and the spacer on the long top bolt going into the engine block. This also worked for Willie.
<b>
</b>
<----you do this alot when trying to understand them...
later
larry
Old Mar 13, 2002 | 01:17 AM
89ProchargedROC's Avatar
Re: Anybody with a Procharger
be more specific: crank, blower, or tensioner pulley?
yes, also make sure that you have the CORRECT LENGTH. I sent back 3 belts before i had the right one from ATI
ATI's instructions are as useless as **** on a bull
Old Mar 13, 2002 | 08:33 AM
KS91Z28's Avatar
Thanks for the help guys. It turns out that they didn't machine down the aluminum spacer far enough to fit in the center groove on the crank pulley. I threw it on a lathe and turned it down a little and now it fits great. The wobble is gone.
Old Mar 13, 2002 | 09:57 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
also try goodyear gatorback belts they seem to give you another #
Old Mar 14, 2002 | 08:39 AM
KS91Z28's Avatar
Are they less likely to slip or something?
Old Mar 14, 2002 | 10:36 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yep, they are the hook up.
Old Mar 14, 2002 | 11:06 AM
KS91Z28's Avatar
Where in the heck can you get Goodyear Gatorbacks from? I've called every parts store in town and nobody carries them or if they do, they can't get them in the size I need.
Old Mar 15, 2002 | 10:05 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I can only get them from my wharehouse and they are like around $60, requests for them can be made at outlawmgmt@aol.com
Old Mar 15, 2002 | 10:45 AM
KS91Z28's Avatar
Ok, I finally found a place about 30 min. away that can get them in a size just a little smaller than my current Gates belt. The Gates belt is 66 inches long and the Goodyear Gatorback belt they can get is 8/10ths of an inch smaller. He said it would be $30.88 (before tax).
sleprock
Oct 1, 2015 09:39 AM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
