Toluene Discussion
Old Mar 18, 2002 | 05:54 PM
MouseCamaro305's Avatar
Toluene Discussion
can anyone give any information on Toluene? (estimation on price, where to obtain toluene, proper mixing ratios, personal experiences) those would all be great, and really helpful.
Thanks a lot guys
Old Mar 18, 2002 | 07:12 PM
Jester's Avatar
you can get it at Home depot for pretty cheap. I forget what ratios you actually have to mix it in tho..I think I saw it in a tech article on the turbo buick board.
Old Mar 18, 2002 | 09:08 PM
ok thanks for the info, anyone have any other info on toluene, jester, do you by any chance know what octane numbers the addition of toluene is capable of producing?
thanks again
Old Mar 19, 2002 | 09:09 AM
scauffiel's Avatar
Do a google search on toluene and octane boost and you will come up with a lot of hits.
S.
Old Mar 19, 2002 | 04:03 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Toluene-R+M/2--114 w/92 gas
10%-94.2
20%-96.4
30%-98.6
Xylene--117 w/92 gas
10%-94.5
20%-97.0
30%-99.5
Methyl-Tertiary-Butyl-Ether (MTBE)--118 w/92 gas
10%-94.6
20%-97.2
30%99.8
MTBE is extremely dangerous to human skin, and humans in general if you come in direct contact with it. 1tsp. is enough to kill a man.
Old Mar 20, 2002 | 09:10 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Can you buy just plain toulene or do you have to "find" it in some kind of solvent?
Old Mar 20, 2002 | 04:12 PM
johnsjj2's Avatar
Car: 1991 Z-28
You should be able to buy it at a paint store. The Meijer here in Lafayette sells it in gallon cans. THe MTBE you won't be able to buy unless you have some super kick a$$ connections. That stuff is regulated much the same way freon is.
Old Mar 21, 2002 | 10:21 AM
ok thanks a lot guys, for the responses, if anyone has any additional information, please share it with us.
thanks again
Old Mar 21, 2002 | 02:35 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
If I remember correctly toluene is very similar in benzene in the fact that it is a cancer causing compound. Just be carefull with it and use rubber gloves in a well ventilated area or leukimia could become a problem after years of handling.
Old Mar 21, 2002 | 02:36 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Tastes good on pancakes though!
Old Mar 21, 2002 | 03:01 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
We used to use Toluene at on the aircraft engines we build. It was band and discontinued because of its dangerous side effects and we use lots of dangerous products.
Old Mar 21, 2002 | 08:46 PM
thanks again for the replies, l wasnt able to find it at either home depot or ace hardware, but lm still looking, is it conventionally used as a paint thinning agent?
Old Mar 22, 2002 | 09:00 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
isnt there already toluene in gas? how about if you put this stuff in 101LL AV GAS?
Old Jan 30, 2003 | 06:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
check this out http://www.elektro.com/~audi/audi/toluene.html
Old Jan 31, 2003 | 07:55 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Toulene is added in the refinery process of oil to make gasoline. Toulene and Xylene do burn at a higher temperature than gasoline. Sherwin williams usually has it for a bout $6 and change(a little cheaper than home depot). Mixing Xylene with 100 octane race fuel would give you 104.2 octane(Sunoco used to have it). Taht'd be more than enough octane for most performance apps.
It is a corrosive as well as combustible solvent so you need to add a little oil to the mixture(I usually mix 1 capfull of marvel to 4 gallons of 94 with 1 gallon of Xylene). I t will eat through the rubber lines of the fuel system if proper lubrication isn't used.
Indy racecarsused to used 80% toulene but needed a fuel heater to get it to vaporise in order to combust. Mixing to much(30% max) would slow the burn rate dramatically and possible have ill efeects on the combustion process.
PETE
Old Feb 1, 2003 | 05:00 AM
83 Crossfire TA's Avatar
Also tends to clean things out making it impossible to read plugs...
InfernalVortex
Apr 20, 2021 11:31 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
