"mini blower"
Old Apr 12, 2002 | 04:18 PM
Fast3rdGen's Avatar
"mini blower"
would it be safe to put one of those weiand or holley single quad blowers on my motor with hyp. pistons? also how much boost can you get out of one of those "mini blowers" and what kind of power gain does it give. my motor is 9.6:1 compression.
Old Apr 12, 2002 | 06:43 PM
daverr's Avatar
i say go for it
i say go for it it should be good for about 100hp.For 1200-1500 those little blowers are not bad,not bad for the price.
Old Apr 12, 2002 | 07:09 PM
maniacc's Avatar
with your set-up i wouldn't recommend it, the roots style blower creates alot more heat then a centrifugal blower, your compression @ 9.6:1 is on the very top of the scale for a blown application, so you would not be able to run very much boost without detenation, also the hyper piston are considered very fragile when detenation occurs, one slight lean condition and you'll be replacing your lower end.
this is just my personal opinion
larry
Old Apr 12, 2002 | 07:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
if fuel quality is kept up and boost and timing stays conservative then you could be ok.
Old Apr 14, 2002 | 09:17 PM
DABE's Avatar
welp...should i do it...i was thinking the same thing...look at sig for my mods...heads are comming soon....
DABE
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
75bike
Sep 20, 2015 09:37 PM
Magman
Sep 13, 2015 12:07 AM
09ave
Sep 7, 2015 06:03 PM
