Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
displayed member info sugestion
Old Oct 15, 2003 | 09:54 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
out of desperation I just joined a MB using the exact same fourm prog as our own TGO to help a friend fix a car.
just so happened they have a neat little set up for the member info that is displayed that we could use and benifit from here IMOP.
where the avatar and member name and souch are this is what is displayed.
Dragons91RS
Registered User
Year: 1991
Car Type: Camaro
Model: RS
Displacement: 5.0
all that is diffrent is the year,car type,model, and displacement. but I think if that info was added here it could help.
with that info automaticaly included when some one makes a post esp if they are new it could help us in answering there ??'s with out having to ask what they have.
Old Oct 15, 2003 | 09:58 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
so basically your saying to put the basic info from one's sig into the name area. not bad but that is why they have a sig option.
Old Oct 15, 2003 | 10:02 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Exactly.
Old Oct 16, 2003 | 12:14 AM
JT's Avatar
JT
Community Administrator
That was one of the things i suggested to the Admins many months ago. But i never heard anything. That trick is so easy to do. There are so many things that can be done on vB's software.
Old Oct 16, 2003 | 06:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
maybe if we do that, we won't have to see everyones sig 40 times in the same post. some of us who are 'bandwidth challanged' don't like to have ot wait for large sig pics to load.
Old Oct 16, 2003 | 09:06 AM
MdFormula350's Avatar
User cp options
Thread View Options
Show user's signatures in their posts? Yes or No
just some f.y.i for Dewey316
Old Oct 16, 2003 | 09:10 AM
JT's Avatar
JT
Yeah, that will work for his bandwidth issue, but then, he wouldn't be able to tell the vehicle's info which is probably why he posted in this thread to begin with.
It really is such an easy setup, and it's would be more uniform to see right away, the person's vehicle info in their postbit instead of just the signature.
Old Oct 16, 2003 | 09:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
MD,
the problem with that is, there are so many thread tha say, what can i do for this issue, mods in sig.
if i turn of sigs, then i can't see that info, and can't help people. personaly i don't come her to get help, i hang around because i like to help others.
Car: 91 Camaro RS
Engine: 305 LO3
Originally posted by MdFormula350
User cp options
Thread View Options
I was just going to mention some thing about that. with the info I suggested a user like himself can disable sig's, but still be able to see the members car info.
also one of my main reasons for sugesting it was new members.
I notice alot of times new members post dont have a sig yet, and forget to mention the car info. with this info added to the registration and automaticaly displayed that wouldnt happen.
also I dont have a problem changing my avatar, but I would like to know what was wrong with it? Ive been using it for several months and no one ever said any thing about it.
Old Oct 16, 2003 | 09:38 AM
JT's Avatar
JT
Very true. That was one of the things i mentioned when i suggested this feature a long time ago, that several don't place their car's info in their post or signature and sometimes when they ask a question, the answer to their question depends on the vehicle's info.
If it was in the user's profile, you could also set it to be required when new people registered so they would have to fill out that info and it would also help remind them, too.
I made that change to the board i administrate a long time ago and it was a useful change.
Old Oct 16, 2003 | 05:41 PM
Administrator
It's done. By going to your User Cp you can now list your car, engine, and transmission.
Old Oct 16, 2003 | 05:57 PM
JT's Avatar
JT
It's not completely done, though. You don't have the info displayed in the postbit. If you need help, let me know.
If it's not displayed in the postbit, then it won't be displayed where the people here was referring to.
Old Oct 16, 2003 | 06:00 PM
Administrator
Yup, hold on. Fixed now.
Old Oct 16, 2003 | 06:01 PM
JT's Avatar
JT
Have you tried it?? It doesn't work. Not trying to be an a$$, just telling you.
It's optional. If you list your stuff, it will appear.
Old Oct 16, 2003 | 06:46 PM
JT's Avatar
JT
All you have to do is:
In the Admin panel, go to the User Profile Fields section and click on Modify. Hover your mouse over the "Edit" URL of each field: Car, Engine, Transmission. Note the last string of each URL, that will tell you the profile field ID (profilefieldid=X). Since i don't have access, and i have no idea how many other custom profile fields you may have tried in the past, those numbers can be just about anything. Remember which number is for which field.
Now, go to the Templates section, click on Modify. Find the Style Set that your board is running. Click on the Expand list under that style set. Click on Expand next to the Postbit Templates section. Click on the Edit link next to the postbit template.
In that section, find:
Posts: $post[posts]
Add a <br> after the [posts] line then add the following:
Car: $post[fieldX]<br>
Engine $post[fieldX]<br>
Transmission: $post[fieldX]
Make sure you have still have the </smallfont></td> after the above.
In the above, where X is after field, enter the appropriate profile field id as i mentioned above. Like
Transmission: $post[field6]
i am not too good at explaning things. Let me know if you need help.
Old Oct 16, 2003 | 07:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Heh, cool, I like it. It does seem redundant though, since my sig is short already! And it's showing up for people that don't have information in there (that's how I noticed that I should probably fill it in, and see if there were any messages up in this forum about it)
Old Oct 16, 2003 | 08:07 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I like it
Old Oct 16, 2003 | 08:20 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Cool! Just noticed this while reading a thread.
Old Oct 16, 2003 | 08:47 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
On some other boards they have a selection box for what year and car you have to deter people who want to list every car they have, so we would have a Year box a Camaro/Firebird box and a box listing models of each with a clickable link that takes you to the Readers Ride if you really want to know what mods etc they have. Probably a pain to script but at some point it might be a good idea. The way it is now is a step in the right direction but you should be able to turn it off.
Old Oct 16, 2003 | 08:52 PM
JT's Avatar
JT
I agree that it should be prefilled with options that the user must select, rather than allowing the user to fill out the info. It's another way for someone to abuse it if it's left open like that.
It's not hard to script that at all. And, it would be much better for future database work and plans.
Old Oct 16, 2003 | 09:10 PM
demonchild's Avatar
i like the idea. hopefully no one ruins it for the rest of us. people always seem to need the mods telling them how to be responsible.
Old Oct 16, 2003 | 10:14 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
But what if I have 3 fbodies???
Old Oct 16, 2003 | 11:45 PM
Car: 91 Camaro RS
Engine: 305 LO3
I agree. my reason for suggesting this was to make it a little easer in helping people, esp new members. not to cause problems for the admin, and mod's.
One thing is for sure. no one can say the current administratior doesnt listen.
I say your doing a good job IROCZTWENTYGR8
Old Oct 17, 2003 | 12:35 AM
Administrator
Thanks. Gotta give Dirk credit too.
Old Oct 17, 2003 | 06:16 AM
Dewey316's Avatar
Car: 1990 Camaro RS
maybe we can make a little sticky asking people to fill that info out?
Old Oct 17, 2003 | 12:50 PM
iroc22's Avatar
You need to make a character restriction. Some are wayyy too long.
Old Oct 17, 2003 | 02:14 PM
Car: 85 Camaro SC
Engine: V6
How long is too long? I dont mind if its just 1 line long.
Old Oct 17, 2003 | 02:17 PM
Dewey316's Avatar
Car: 1990 Camaro RS
well, in my mind something like this is starting to get too long.
Car: 1984 Camaro Z28; 1990 Eagle Talon TSi AWD
Engine: Buick Turbo 3.8L v6; 4G63 with 14b (FP Green on the way)
Transmission: 200-4R; stock T5
Old Oct 17, 2003 | 03:12 PM
JT's Avatar
JT
Right. That is why a prefilled/select box would be a good idea. i own more than just two gta notchbacks, but it is sorta irrelevant to this site.
Old Oct 17, 2003 | 03:56 PM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
Yep it is too long, smaller font+prefilled boxes with clickable linky. Can't go wrong there. Transmission and engine would not be necessary then.
Old Oct 17, 2003 | 05:23 PM
AaronIROCZ's Avatar
so no luck for me??? Just kidding
Bubbajones_ya
Jul 6, 2024 08:32 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Linson
Sep 21, 2015 01:08 PM
Mdenz3
Sep 17, 2015 08:36 AM
dinkrdsw
Theoretical and Street Racing
Sep 11, 2015 06:58 PM
