Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
SERVER NOT FOUND and TIMEOUT errors
Old Feb 17, 2005 | 11:31 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Is anyone else running into this problem? During the day, when I would think the traffic should be the lowest, I almost constantly get "server not found" and timeouts when moving around in the various forums and search screens. And it doesn't appear to be a work related issue, since I get them from home at well. I doubt it's a PC issue either, since its less than a year old and happens on multiple PCs. It makes it really frustrating when one screen comes up in 10 seconds, and the next one times out or erros out after 30 or whatever seconds. Makes it real hard to use the boards.....
Old Feb 17, 2005 | 12:16 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: SERVER NOT FOUND and TIMEOUT errors
the only problem I'm having is that the board is really slow. If it's timing out, I don't wait that long to see....
Old Feb 17, 2005 | 12:51 PM
JT's Avatar
JT
Community Administrator
i have not seen any timeouts personally, but i'm sure Dirk or Iroc would have more info.
There are slow periods, though. i know that Dirk was logged in and doing some server work lastnight. So hopefully Dirk will get things working more smoothly. If not, atleast the new server should provide relief once Dirk gets to it.
Something to keep in mind, even if it is during the day where you think there would be the least amount of traffic, server load is more affected by what those users are actually doing.
Even if there is a low amount of users online, if there are several of those users who are doing things like searches, that is going to place a larger load on the server than people who are just browsing. It is more about what those users are actually doing, than the amount online.
The server load has been kind of high. At the time of your post, the server load was in the double digits, and it wasn't just a quick spike, as the load history was pretty much high over a small period of time.
Old Feb 17, 2005 | 12:55 PM
vernw's Avatar
OK, thanks guys. Appreciate the feedback. I'll just try to be patient until we get the new server in.....
Old Feb 22, 2005 | 08:58 AM
CaysE's Avatar
Actually, I just saw a timeout when I clicked this thread. I had to click Back and click the thread again to see it.
Old Feb 22, 2005 | 12:45 PM
vernw's Avatar
It's actually been running much better today for me....
Old Mar 15, 2005 | 11:14 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
https://www.thirdgen.org/techbb2/sho...hreadid=279035
Old Mar 15, 2005 | 12:15 PM
JT's Avatar
JT
Would you have any status? Has the new server been put together? Or, any chance that the new server is in the stress test phase?
People would probably better like to hear an update on that old information
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
WickedBowtie
Sep 11, 2015 11:24 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
gt4373
Sep 9, 2015 10:29 AM
