Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Rpo Decoder Not Working
Old Mar 2, 2005 | 09:34 AM
mike macedo's Avatar
Car: 87 Trans Am ws6
I WENT TO USE THE RPO DECODER TODAY WHILE @ WORK. A CO WORKER OF MINE JUST BOUGHT A TOTALED CAMARO AND IT NEEDS A REAR END HOUSING. WEN I WENT TO GET THE REAR END GEAR CODE BUT THE DECODER ISNT UP. THE CODE IS GU6 . I USE THIS THING ALOT HOPFULLY WE CAN GET IT FIXED
Old Mar 2, 2005 | 02:38 PM
JT's Avatar
JT
Community Administrator
If the RPO decorder was up, it would show Gu6 as:
AXLE REAR, 3.42 RATIO
Due to a hard drive crash on the server several weeks ago, it has taken time for TGO to restore everything back to normal. The RPO section is one of several things that still needs work.
In the mean time, many of those codes can be found on this forum when doing a search, as often times people come here to ask some type of question related to those codes.
hectre13
Dec 11, 2023 08:14 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
