Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
"Power Adders" forum
Old Jun 18, 2006 | 05:19 PM
Steven89Iroc's Avatar
Could someone please rename that forum to "Forced Induction" or similar?
Every 5 minutes or so it seems a newbie is posting questions about which air filter/exhaust/pulleys will "add power" to his car, which obviously has nothing to do with superchargers/turbochargers/nitrous.
Just a friendly suggestion, thanks for reading.
Old Jun 19, 2006 | 01:24 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
It's been OK like that for years. If they can't read the description we'll just ban.
Old Jun 19, 2006 | 06:37 PM
Okay, go ahead and get started.
https://www.thirdgen.org/forums/powe...e-no-clue.html
https://www.thirdgen.org/forums/powe...hips-ebay.html
https://www.thirdgen.org/forums/powe...-what-buy.html
https://www.thirdgen.org/forums/powe...dders-tpi.html
(Though this one did turn into a turbo thread)
https://www.thirdgen.org/forums/powe...68200-hey.html
https://www.thirdgen.org/forums/powe...hp-torque.html
And those are only from the current first page.
The forum description doesn't really limit it to the three it mentions, it simply makes it sound like those are only a few ideas for adding power. I could understand that point if the description more clearly stated what the forum was for, but some of the newbies (and maybe even some oldies) aparently can't tell the difference.
BTW, my laptop has ran OK like this for years, but that doesn't mean it doesn't need upgraded now.
I'm not trying to be rude, just trying to help you understand my points.
Old Jun 19, 2006 | 07:20 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I agree. Not only is it annoying to have those posts. But, when searching thru that forum, it ruins your search results also. Calling the the forced induction forum, would hopefully limit those posts that are not fit for that forum.
Old Jun 19, 2006 | 08:10 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
I think thats a good idea renaming it "Forced Induction". It would make more sense IMO.
Old Jun 19, 2006 | 08:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not all power adders are forced induction though... "Forced Induction & Nitrous Oxide" maybe
Old Jun 19, 2006 | 08:34 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I agree.
Old Jun 19, 2006 | 09:18 PM
Nitrous is a form of forced induction, you're forcing it into the path of induction, right?
At any rate, I imagine that's why they chose "Power Adder" to begin with, but I don't think the other would hurt as long as a simple, clear explaination follows. "Forced Induction & Nitrous" would probably work just as well anyway.
Old Jun 19, 2006 | 11:28 PM
Engine: 355 TPI
I do believe technically speaking, nitrous is a form of forced induction.
Old Jun 20, 2006 | 12:33 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really, unless you're spraying so much that you're pressurizing the intake.
Old Jun 20, 2006 | 04:46 PM
Semantics... That is beside the point. As I said; either title would work, just simply explain it in the description.
It may not slow down those posts if the description only was changed, but then at least we'd have a valid reason to yell at people.
Hey look, another one!
https://www.thirdgen.org/forums/powe...est-t-p-i.html
Old Jun 20, 2006 | 06:46 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I agree with ape: "Forced Induction & Nitrous Oxide"
Or maybe "Blowers, Turbos & Nitrous" or something like that...
Old Jun 20, 2006 | 07:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, I never frequent this board, but that's a good idea.
Forced induction & nitrous. I like that.
Old Jun 29, 2006 | 04:26 PM
'86 350's Avatar
Car: '86 Camaro SC
I've been on there before, even tried to do a few searches and I noticed that. Really annoying. I agree on the renaming it "Forced induction and Nitrous."
RedLeader289
Jan 22, 2016 03:05 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
