Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
login trouble!!!!
Old Aug 5, 2006 | 05:57 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
login trouble!!!!
when I click to remember me on login when I go to TGO it says page cannot be displayed...I have to login then backup yo get into the site...And It has been taking forever to load the homepage when I have been trying to access in for the past couple weeks...Thanks...Dave
P.S.I'll check this if I can get back into the site...
Old Aug 5, 2006 | 07:37 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Same here, I can't log in using the home page I have to use the forum post a reply and only then can I log in. Also all day today 8-5-06 I tried to get to the site and all I got was page can not be displayed.
Old Aug 5, 2006 | 08:06 PM
JT's Avatar
JT
Community Administrator
Was you just trying to access the front page (www.thirdgen.org)? Or was you trying to access the forums directly (www.thirdgen.org/techboard) through a bookmark?
Old Aug 5, 2006 | 08:13 PM
dwillis's Avatar
Axle/Gears: 3:08
just trying to access the homepage.....now if I'm not logged in I can access the home page...but if I am logged in I cannot access thirdgen.org...I have to go straight to the techboards....
Try to clear your cookies on your pc and then access the page...log in then when it says cannot display page...go straight to thirdgen.org/techboard/ thats what I have to do..
Old Aug 5, 2006 | 08:19 PM
JT's Avatar
JT
OK. I'm fairly sure it is the APC module that was re-enabled a few days ago. We had this exact issue, intermittent, last time it was re-enabled. I'm pretty sure that the last time it was enabled, this issue didn't immediately appear.
Old Aug 6, 2006 | 12:47 AM
dwillis's Avatar
Axle/Gears: 3:08
Well It has only been doin it really bad for the past few days...so hope that helped you guys get closer to finding a solution...thx.....Dave
Old Aug 6, 2006 | 08:04 PM
AaronIROCZ's Avatar
Yes it was while trying to access through the front page
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
