Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Problem With Images in Posts
Old Dec 30, 2006 | 03:44 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I am not having any success embedding images into my posts, as I have done many times in the past. I am following the same procedure I have always used, and instead of the images appearing, they are appearing as hyperlinks.
Take this thread for example:
https://www.thirdgen.org/forums/misc...actory-gm.html
Any suggestions?
Thanks in advance.
Old Dec 30, 2006 | 03:56 PM
JT's Avatar
JT
Community Administrator
That's because your URLs had, for one example, "?t=1167505040" after .jpg (extension). The vB software is setup to treat those types of URLs differently.
In your case, it appeared to be unncessary, so I fixed your post by removing them.
Old Dec 30, 2006 | 05:10 PM
Bull's Avatar
Engine: LT1; None
Thanks very much for the help.
I wonder, though, why this is happening now? As I said, I have been using Photobucket and embedding images in posts on this site and others for a long time. Any theories?
Thanks again for your time.
Old Dec 30, 2006 | 05:28 PM
JT's Avatar
JT
Maybe I didn't explain it well. If you want to embed images in posts, make sure the URL ends in .jpg or .gif. If there is any trailing behind .jpg or .gif, the forum will convert it to a link, regardless if you used the image tags.
I searched some of your posts where you embedded images specifically from Photobucket. Some were from a few days ago, some was from 2005. All of them ended in .jpg - which is normal. That's why those images displayed properly in your posts.
However, this recent example is the only example I could find where you tried to embed photos from Photbucket that had a suffix at the end of .jpg ( .jpg?t=1167505040 ). That is where the problem was. The forum software treats URLs differently that end in anything other than normal .jpg, gif, etc., extensions.
Since I don't use Photobucket, I can only guess that the URL you got from Photobucket was different than what you normally had used.
Old Dec 30, 2006 | 05:34 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Photobucket just recently changed the way you have to copy the URL.
Old Dec 30, 2006 | 08:35 PM
Bull's Avatar
Engine: LT1; None
Thanks so much for the effort in checking into and explaining this to me, JT.
flrtin1, that would explain it! What is the new way that you have to do it?
Old Dec 30, 2006 | 09:11 PM
JT's Avatar
JT
That worked, but I can't say that it will always work.
Old Dec 30, 2006 | 11:01 PM
flrtin1's Avatar
Engine: S/B
If you left click over the words IMG Code of the image you want on your photobucket thumbnail page you will notice a little yellow pop up that says Copied then just paste that into your reply as is and you will be good to go.
I have the line you want to click on circled in red on the first image on this screen:
Old Dec 30, 2006 | 11:17 PM
flrtin1's Avatar
Engine: S/B
Heh sorry I had right click and ment left click lol so I edited it
Glowsock
Jul 24, 2025 03:15 PM
Terrell351
Jun 13, 2021 01:13 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
project89
Sep 24, 2015 06:38 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
