Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Editing posts with images
Old Jun 23, 2008 | 09:57 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Is this a setting I can change? It's incredibly annoying when I try to edit a post and my full size image shows up in the type field. What if I want to edit my image tags or change the URL my image tags refer to?
Old Jun 23, 2008 | 11:43 AM
JT's Avatar
JT
Community Administrator
Re: Editing posts with images
You will need to give me an example because after re-reading your post, I'm still not certain what the issue is and what you are trying to accomplish. What do you mean by full size image shows up in the type field?
Old Jun 23, 2008 | 03:29 PM
JT's Avatar
JT
On second review, and checking your account, I now believe I understand the issue.
I see your account is using the Full WYSIWYG editor for the message interface editor. When you edit a previous post that contained any images, those images appear inside the editor instead of the URL path as you are using the "WYSIWYG editor". If you use the Standard Editor, when you edit a previous post that contains images, the URL path will be shown instead of the image itself, which may make it easier for you to make adjustments to the URL.
In short:
Go to the User CP: https://www.thirdgen.org/forums/usercp.php
Click on Edit Options
Scroll down to Message Editor Interface
Select Standard Editor
Chuck84TA
Jul 15, 2016 09:05 PM
MoJoe
Sep 24, 2015 09:12 PM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
