Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Links to other posts on TGO
Old Jan 5, 2009 | 04:11 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
I've been having this problem for a while now. Whenever I try to post a link, like this one (to my for sale thread), which just leads to another page on the TGO message boards. I dunno what you want to call it, "internal link" sounds good to me... Anyway, after I just post it up like that with the default options checked ("Automatically parse links in text" & "Automatically retrieve titles from external links"), when the link is clicked on it comes up with "Page Not Found." But, when I disabled those options, it would work fine...
Well now, wouldn't that figure... It has been happening to me very consistently for weeks, now it works fine. Well, I feel like an idiot...
So, with that apparently no longer a problem... I have another question. Is there a way to disable the automatic retrieval of the post title? It is sometimes inconvenient to have it automatically add in the title of the thread you are linking to... Not a big deal, just curious.
Old Jan 5, 2009 | 04:53 AM
JT's Avatar
JT
Community Administrator
Re: Links to other posts on TGO
This is a global feature that can't be customized per user. It's part of the vBSEO plugin that we use which basically takes vB's links (which are usually meaningless with php) and rewrites them into links that are identified by the forum and subject title. We've had this feature for just over 2 years now.
For example, the original vB link to this thread would be (without vBSEO):
Code:
https://www.thirdgen.org/forums/showthread.php?t=506394
With vBSEO:
Code:
https://www.thirdgen.org/forums/problems-help-suggestions-comments/506394-links-other-posts-tgo.html
The vBSEO plugin was installed for search purposes, as well as the benefit of allowing members to see more of the type of link they were clicking on (as shown above). If a member was presented with the two links above, they can easily see what forum the link resides in and what the subject of the link is.
What you are asking is if you can override vBSEO from inserting the internal subject title of the link. As mentioned, this is not possible on a user basis. It's a global feature that's either on or off.
Old Jan 5, 2009 | 05:07 PM
BlueIroc-Z's Avatar
Like this.
Ah ha, ^ that link is doing the thing that I originally posted about... The url I put in for the link was:
Code:
https://www.thirdgen.org/forums/interior-parts-sale/488049-1984-berlinetta-parts.html
but after posting, clicking on it takes you to:
Code:
https://www.thirdgen.org/forums/!488049!https://www.thirdgen.org/forums/interior-parts-sale/488049-1984-berlinetta-parts.html
Probably just a fluke that happens when I go back and forth editing over and over again. Sometimes going into the "Advanced" editing page, some times not...
Nevermind again, I guess... Apparently all I have to do is refresh the page after posting and the links are resolved properly, but the parenthesis thing comes up. See below...
Old Jan 5, 2009 | 05:29 PM
BlueIroc-Z's Avatar
Anyway, for the other issue, I meant how when you add a link to another thread, and when you post it it automatically adds the title of the thread in parenthesis following the link. See below...
Link. <--It adds the part in parenthesis automatically...
Old Jan 5, 2009 | 05:47 PM
JT's Avatar
JT
Like this.
Ah ha, ^ that link is doing the thing that I originally posted about...[COLOR=Black] The url I put in for the link was:
Code:
Code:
That is a bug I discovered with the vBSEO plugin we are running. It appears to surface if you use Quick Edit on a post that contains an internal link. It causes the above issue that you note (note the insertion of exclamation marks in the URL and the double board URL - which makes the link dead). The advanced/full edit does not have this bug.
Yes, I understand. The adding of the parenthesis is part of the vBSEO plugin and there is no default way to turn that off. I suppose with some advanced coding that could be possible. However, in the 2 years we've had this feature, there has been few reports of this being an issue. It's only an issue when someone wants to be "advanced" and manually edit an internal link inside a post.
Old Jan 5, 2009 | 05:51 PM
BlueIroc-Z's Avatar
Ok, cool, that answers my questions. Thanks for your time.
Old Jan 5, 2009 | 06:09 PM
JT's Avatar
JT
I hope to upgrade the vBSEO plugin, which should resolve the bug that was pointed out above. In addition, I strongly suspect it is also a source of another bug we have, which should get resolved as well. I don't think it will give the ability for "advanced" URL linking without the automatic insertion of the subject, as you requested, but we can look when that time comes. Hopefully we'll have some progress.
Thanks.
Chuck84TA
Jul 15, 2016 09:05 PM
Thirdgen89GTA
Aug 25, 2015 06:40 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Linson
Aug 21, 2015 02:12 PM
