Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
issues with my Signature
Old Sep 17, 2011 | 04:43 PM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
it will only post my Sig in my first post and not after that. is there any reason for that?
Old Sep 17, 2011 | 05:02 PM
JT's Avatar
JT
Community Administrator
Re: issues with my Signature
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show.
However, if you reply to an existing thread, and if you want your signature to display, you will have to manually place check in the box for "Show your Signature" each time, which is the option below the where you type your message.
This helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times. It's been this way for several years.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
