T5 Clutch pedal assembly
Old Mar 26, 2016 | 08:21 AM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Good condition pedals, the pads on them are like new. Looking to get $100 plus shipping, located in CT. Also have a shift plate for those looking to do a 5 speed conversion
Old Mar 26, 2016 | 02:16 PM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
Re: T5 Clutch pedal assembly
Old Apr 2, 2016 | 02:26 PM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
still for sale?
Old Apr 2, 2016 | 03:28 PM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
Originally Posted by formula00ra
still for sale?
Yes it is!
Old Apr 2, 2016 | 04:27 PM
Engine: 350 ci
how bout 100 shipped to 19904
Old Apr 2, 2016 | 04:36 PM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
PM sent
Old Apr 6, 2016 | 03:26 PM
GeneL's Avatar
Car: 1983 Camaro Sport Coupe, T-Top
Engine: LG4 5-Liter V8, 305cid
Transmission: NWC-T5 Manual 5-speed
Axle/Gears: GU5 Axle Ratio 3.23 Rear
It would appear you've already sold it, but if not...
would that work to replace the squeaking/creaking/groaning Pedal Assembly in my 1983 Camaro Sport Coupe LG-4, 5-Liter V8, 305cid, 5-Speed Manual?
Thanks!
GeneL
Old Apr 6, 2016 | 04:17 PM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
Thanks!
GeneL
Yes I sold them. I would recommend that you just try lubricating yours with some WD-40 first before replacement however
Old Apr 6, 2016 | 05:03 PM
1992 Trans Am's Avatar
Engine: 5.0L 305ci TPI
Axle/Gears: 3.08
If it only makes that noise when using the clutch and not the brake, I would suggest replacing your clutch master cylinder. When those go bad, sometimes there is a squeak-like noise that you hear when you depress the clutch pedal.
Thanks!
GeneL
Old Apr 6, 2016 | 05:52 PM
GeneL's Avatar
Thanks for your reply.
The clutch on this'83 has been nothing but trouble since I purchased it back in January of 1983 (yes, I'm the original owner). This is about the third Z-bar/Bellcrank and fourth clutch over the years (maybe the fifth, I've lost count). I had the most recent clutch installed in September of 2015 and it has never worked at optimum (some occasional gear grinding). "Clutch Guy" says it cannot be adjusted properly because of the pedal assembly. That, along with the pedal being hard to press and the creaking and groaning has led me to research a replacement.
Yes, he did oil/grease it, but to no avail.
I'm hoping a pedal assembly replacement will be the fix.
GeneL
You can hear the noise as I depress the clutch in this YouTube video I posted at the time of the latest clutch install. I made the video on the topic of squealing noise related to the clutch release/throwout bearing (since been resolved).
Old Apr 6, 2016 | 05:59 PM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
GeneL
Clutch release bearing/throwout bearing squealing noise - YouTube
A problem you might face is your car I think has the mechanical clutch, this one I sold was hydraulic so you would have to change a lot to make it work
tealman92
Nov 14, 2021 07:36 PM
Loudnproud86
May 26, 2016 05:20 PM
hotrodjames
May 9, 2016 11:52 PM
86IROC112
Mar 26, 2016 04:38 PM
I_R_GRUNT
Mar 20, 2016 11:03 AM
