89 Camaro steering box cracked frame
Old May 4, 2016 | 01:34 PM
beansandmia's Avatar
Hello, I have a question, is it possible to have the front frame rail rebuilt to mount the steering box to the frame or I was told the frame is a 2 piece and I could get a new front frame and have it welded. Here are a few pics, any thought welcome please!
Attached Thumbnails 89 Camaro  steering box  cracked frame-img_2775.jpg   89 Camaro  steering box  cracked frame-img_2773.jpg   89 Camaro  steering box  cracked frame-img_2772.jpg
Old May 4, 2016 | 03:40 PM
Mirror Image's Avatar
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: 89 Camaro steering box cracked frame
From the looks of it its rusted out you may need a new frame rail you can find them T/A creations have them
Old May 5, 2016 | 08:05 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Transmission: MK6
Axle/Gears: 3.45
That crack is a huge safety issue, have that section of the rail replaced and welded in. Failure will be catastrophic when it lets go. Just my two cents.
Old May 8, 2016 | 11:45 PM
The car isn't being driven, we had it towed. We took out the broken steering box. What we aren't sure of is, is it a k member that we would need to replace or when you hear talk of replacing the front clip? We have found a whole front end, I'll add the pic. My friend isn't sure what part I need to get to replace this and fix the problem, without patch welding a piece on.
Old May 9, 2016 | 09:32 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If everything comes out the way it should you can mount a "steering brace" AKA Wonder Bar to help prevent that.
Link = https://www.thirdgen.org/forums/afte...r-bar-1-a.html
Old May 10, 2016 | 12:41 AM
The whole thing had broke off so he just pulled the steering box out as it was leaking. Prior owner had installed a wonder bar but as it seems that was a little to late because it broke completely off the frame. I'm just not sure what we need to buy to fix it if we don't want to fabricate a piece and weld it on......?
Old May 10, 2016 | 09:25 AM
1o80b's Avatar
Old May 16, 2016 | 10:49 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, it costs less to buy and install a steering brace (aka wonderbar) than to repair the cracked frame the steering gear box is mounted to.
http://www.top-downsolutions.com/cha...or-firebird-(a
Lon Salgren
91banditt2
Aug 11, 2021 10:54 AM
articwhiteZ
May 15, 2016 10:57 AM
seanof30306
Apr 22, 2016 04:24 PM
jdost1992
Apr 11, 2016 12:31 PM
