Headers rubbing suspension and chassis
Old Jul 25, 2016 | 11:02 AM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
Does anybody ever had the problem of long tube headers rubbing against the chassis or suspension?
I do.
Old Jul 25, 2016 | 11:18 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Re: Headers rubbing suspension and chassis
Make sure your engine mounts are all good, if they are good, you may actually wind up having to either dent the headers slightly, or grind away a small amount of the frame/ suspension where it's making contact. If one or a combination of these do not gain you the clearance you need, you may have to buy a better fitting set of headers; I' running a set of Doug's Long Tubes in my 1996 IROC and they do not hit the frame or suspension anywhere.
Old Jul 25, 2016 | 05:39 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
I will try that this next weekend
Old Jul 25, 2016 | 06:09 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
I do.
Have you read the sticky on Hooker longtubes?
https://www.thirdgen.org/forums/exhaust/148210-notes-installation-hooker-long.html
Lots of reading, but well worth it. Tell us what headers you have, certainly others on here will have or had the same and can give you tips specific to the brand you're using.
I have Doug's LT as well, they fit great. I had very little clearancing to do, but they were not drop in, even with new stock mounts. No LT header is for third gens. For me, I had to move the brake lines away, grind a weld down on the back right side of the k-member and dimple a few spots in the header tubes before I had them ceramic coated.
Old Jul 27, 2016 | 04:02 PM
no new tires's Avatar
Car: 88 IROC-Z
Don't CUT anything!
Old Jul 29, 2016 | 10:35 AM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
https://www.thirdgen.org/forums/exha...oker-long.html
I'm reading it, thank you.
My headers doesn't say any brand on them
Originally Posted by no new tires
Don't CUT anything!
I'm not cutting anything, I think I will take the car to a shop and they will heat the headers to bend them a little bit to get to the right place so they don't rub.
Old Jul 29, 2016 | 10:59 AM
Lurbie's Avatar
Car: 89 Camaro
Are there any numbers stamped into the flanges?
Old Aug 2, 2016 | 09:03 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
This are my headers...
Old Aug 4, 2016 | 05:59 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Where/what are they rubbing on?
Old Aug 4, 2016 | 01:37 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
Right here....
Old Aug 8, 2016 | 02:09 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
ding them- it's just what you have to do with lower end headers for American cars and David Freiberger proved that you won't kill off any power...
mark where they need clearance, pull them out, and use a chunk of round tubing to spread the blow from the hammer and make it look nicer. those headers look coated, so wrap a rag around the tubing before hitting it. you might still damage the coating, but it's probably already damaged from rubbing, anyways.
i think i had to ding one tube one each side of my Hedmans- one on the front, one on the rear- but they've been in the car since 2012 and it hasn't caused any issues.
Old Aug 11, 2016 | 10:25 AM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
I will do it this weekend.
Will also try to document the process.
jorgeblancojr
Jun 13, 2016 07:51 PM
someone972
May 30, 2016 04:12 PM
IROCDOWNUNDER
May 25, 2016 08:51 AM
someone972
May 18, 2016 11:38 AM
70net440
Apr 27, 2016 07:33 PM
