Fiberglass 85-90 aero spoilers
Old Aug 11, 2016 | 08:40 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Im curious if anyone here as some pictures of the spoiler up close and what vendor they purchased it through. as far as I knew they were all made by the same company but i noticed there appears to be a difference and i wanted to get an idea who is selling what.
Arrow "A" is the front edge of the spoiler the thin edge that you see looking out the back window
Old Aug 11, 2016 | 10:47 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Re: Fiberglass 85-90 aero spoilers
Yours looks like mine. I got it at Classic Industries (pickup). It's ... fair. The third brake light has a gap that drives me nuts, though. Can see it below.
Pretty sure only one company makes them currently.
Old Aug 12, 2016 | 06:57 PM
Engine: ls1, LB9
Thtanner, thanks for the response those pictures are perfect for what i wanted to see. I did notice the third brake light area on this spoiler as well.
the center on the top side of mine is warped and sunk down low. its too bad the pictures do not show this very well. I actually thought of putting some cereal and a spoon in the center to show how sunk it really is compared to the sides but i guess i don't feel that would be right to pick apart the defect more than talking about it
Now if we could get some other guys to post some of the hawks spoiler. this may put some of this into perspective if there is more than one supplier making these.
I had made my own spoiler but its been an off and on project for a few years as i do not have the spare time i used to and realized I still have several hours left in smoothing mine out. cutting and re-glassing the spots to clear the glass clip locations. I thought i was biting the bullet and just getting this out of my hair. I will say the vendor I went through has been very fast at the responses and looks to be on a good path for a resolution.
here are some pictures showing the gap at the front and rear of the brake light and the holes are not in the correct spots.
Old Aug 12, 2016 | 07:53 PM
thtanner's Avatar
Yea, all my mounting holes were seemingly drilled by a drunken person. Way off, by inches! The third brake light holes weren't even close to centered.
Old Aug 13, 2016 | 06:35 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
subd
Old Sep 10, 2016 | 02:41 PM
Engine: ls1, LB9
I talked to hawks this week and confirmed the spoiler they sell is not the same as the OER Classic one. The hawks spoiler is only sold through hawks and no other vendor. I hope to get some up close pictures of that one soon and will post them to compare.
Old Sep 17, 2016 | 12:05 PM
Engine: ls1, LB9
here are some pictures of the hawks spoiler,,
it defiantly has the correct shape on the top side for the dish,
the tips of the arms are not the same shape as the factory unit.
there is a small gap on the third brake light similar to the gap on the OER classic industries unit but not nearly as bad.
the front edge of the spoiler is not thin like the factory but is only 1/4" squared vs the oer classic where it looked like the side of a 1x4 board.
over all im a bit disappointed it is not identical in style to the factory unit. there is some gaps where it meets the deck lid as well but i expected some of that with a fiberglass spoiler from a non-auto-factory (GM,Ford.. ect)
at this point I feel its at least better than what was on the car and I will be painting it and using it.
I wouldn't use this on a show car - but you have limited options... make your own which with mine im still working on it but needed a spoiler on the car. maybe find a skilled fiberglass shop who would be willing to make a copy of the original or whats left of it.
Old Oct 2, 2016 | 08:02 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
What drives me more crazy is how thick the spears are on all of the fiberglass spoilers. The Hawks spoilers I have do not look as thick but they are still thicker than OE Urethane..
Old Oct 3, 2016 | 08:14 AM
dmccain's Avatar
I also noticed mine from classic industries has thicker spears than OEM. The holes were off by maybe 1/16 of an inch here or there but overall id say its a pretty nice fit. Looks a lot better than my old cracked rubber one and so much lighter.
Old Oct 3, 2016 | 08:23 AM
dmccain's Avatar
Old Nov 3, 2016 | 12:01 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Does anyone have pics of the Hawk's aerowing spoiler installed on a car that shows the thickness of the spears? I REALLY don't like the looks of the spears on the Classic Industries spoiler.
I found this one on ebay. From what I can see, the spears appear to be the same, or very close to the factory ones.
http://www.ebay.com/itm/1982-1992-Pontiac-Firebird-Trans-Am-Rear-Wing-Spoiler/122196759481?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40293%26meid%3D54bd9a5ff1cb47319d250095c7ecb888%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D311733141409
Attached Thumbnails Fiberglass 85-90 aero spoilers-firebird-aerowing-ebay-s
Old Nov 3, 2016 | 12:06 PM
Engine: L03 305 TBI
Can you post some pics of the blades with the spoiler installed on the car?
Old Nov 3, 2016 | 12:51 PM
dmccain's Avatar
Recently saw one a guy said came from Hawks and it looked almost if not identical to mine from classic industries. I'm not sure if they are built from the same manufacturer. He didn't put his 3rd brake light back on so I wasn't able to check that. Mine does have a small gap there but barely noticeable.
Old Nov 3, 2016 | 05:24 PM
Engine: ls1, LB9
Nope, like i stated above they are not even close to being the same and hawks is their own spoiler no one else is a retailer for it. that is right from the horses mouth
Old Nov 3, 2016 | 05:52 PM
Engine: ls1, LB9
they are bigger and shaped different than the originals but not nearly as thick as the classic OER style. the bolt holes are a little off compared to stock but not bad still bolts up fine no drilling. the other issue which i think has to do with the minor gap for the third break light is the top side is not flat across it actually raise up in the center a little. the right side has a small gap where it meets the glass and deck lid.
hope these help, if it wasn't so late i would bring it outside and take some better pictures so you could see a side shot
Old Nov 3, 2016 | 06:50 PM
Matt trans am's Avatar
Car: 1985 trans am
Do not buy from that pic. Its showcar. Bought one and had to scrap it and they never answered my complaints
Old Nov 9, 2016 | 12:43 PM
hawksthirdgen's Avatar
Premium Sponsor
HI,
I wanted to chime in to confirm that our spoiler is made IN HOUSE and not purchased nor sold through Classic Ind. We have had great success with our spoiler as well as customer feedback , if you have any questions please feel free to reach out to me to discuss at 864-855-2694 EXT 2101.
Thanks,
Bruce Hawkins
www.hawksmotorsports.com
Old Nov 9, 2016 | 03:02 PM
okfoz's Avatar
I have 2 of the Hawks Spoilers, and I bought a car with the OER spoiler. Hawks Spoilers look way better than the other brands out there. They are closer to the original Urethane Spoiler IMHO.
Old Nov 10, 2016 | 01:20 AM
Engine: L03 305 TBI
Originally Posted by hawksthirdgen
HI,
Thanks,
Bruce Hawkins
Bruce,
Thanks for weighing in and clarifying things.
Is there any way you could post some pics of one on a car, detailing the differences between your aerowing, and the factory one?
I look at this, and it freaks me out.
Everyone has different tastes, but to me, those thick spears make it look like a completely different wing.
Old Nov 15, 2016 | 08:35 AM
Beater79TA's Avatar
Having purchased both the Classic Industries and the Hawks spoilers during a previous paint job, we sent the Classic one back as it was an inch too narrow to mount on the car. From outer edge to outer edge it was an inch too narrow to mount to the glass and the mounting holes didn't line up. In comparison, the Hawks one bolted right on. It might not have been cosmetically identical in every measurement to the original but it also wasn't falling apart like the original was. If these are your two choices, go with the one from Hawks.
Old Nov 22, 2016 | 08:36 AM
Sly72's Avatar
Car: 87 T/A
Engine: 5.0 TPI
Transmission: 5 Spd
Get the Hawks.. I bought mine through Classic Industries and the fit and finish is sub-par.
Should have went with the Hawks.
Old Dec 11, 2016 | 12:04 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Not as tight as the original, but I'm happy with this ( lightweight) Hawks wing!
Old Dec 12, 2016 | 10:44 AM
okfoz's Avatar
Bruce,
That looks like a Classic Ind Spoiler... The one on a car that I bought that came with a fiberglass spoiler looks just like that....
Old Dec 14, 2016 | 08:16 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
do they make the knight rider spoiler ?
Old Dec 15, 2016 | 08:08 AM
okfoz's Avatar
I thought the KR spoiler was the 82-84 Trans Am Spoiler and later 87-92 Base Firebird spoiler. They should be everywhere.
Old Dec 15, 2016 | 08:11 AM
KITT1983's Avatar
i didnt know hawks made a repro ?
Old Dec 15, 2016 | 08:24 AM
okfoz's Avatar
I don't think there is a cal for it, just about every 87-92 Base FIrebird in the junkyard has the base spoiler. There are too many out there in junkyards to make them.
Old Dec 30, 2016 | 01:15 PM
Bradsaundry's Avatar
Car: 85 Trans Am
Engine: 5.7TPI
Has anyone purchased from showcar in Ontario? I purchased one a while ago and the quality seems very poor. Still trying to work out all the waves. Didn't look that bad at first until I threw some primer on it.
Old Dec 31, 2016 | 08:14 AM
rgauder's Avatar
Car: 1987 Trans Am
I think it has been established that everything Showcar sells is garbage.
Old Dec 31, 2016 | 08:17 AM
Opposite of their name, I've never heard anything good about a Show Car part, for anyone concerned about looks/fit/finish (show).
They seem to be adequate for racing, where fit/finish are not the primary concern.
Old Dec 31, 2016 | 09:49 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Exactly what he said.
Old Jan 17, 2017 | 12:24 AM
88Greg's Avatar
Car: 88 Trans am
Axle/Gears: C4 IRS 3.42
Anyone try this unit :
http://www.ebay.com/itm/1985-90-Pont...5XUzfB&vxp=mtr
Old Jan 17, 2017 | 06:00 AM
PurelyPMD's Avatar
That's cheap - just sent a message to find out how much shipping would be.
Old Jan 19, 2017 | 07:44 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
Has anyone used the wing from summit racing? I was thinking of buying from them buy after reading this I'm not so sure. I still have the factory wing but its pretty rotted out. I'm not sure if its fixable or better off to just replace, I can post pics late to get your opinions.
Old Jan 21, 2017 | 03:16 PM
jworks's Avatar
Engine: 5.7 liter
passenger side
driver side
Old Jan 21, 2017 | 04:39 PM
Beyond repair to me...
Old Jan 22, 2017 | 12:54 PM
BrianI's Avatar
I would replace that.
Old Feb 3, 2017 | 09:49 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Feb 6, 2017 | 10:07 AM
okfoz's Avatar
I agree, once it starts to split, and bulge, not much you can do about fixing them.
John
Old Feb 23, 2017 | 05:57 PM
78camaroz28's Avatar
Car: 2001 Trans Am WS6
Knowing what I know now, and more so after reading this thread, I would not have bought my spoiler from CI.
Old Feb 23, 2017 | 06:38 PM
jworks's Avatar
Engine: 5.7 liter
I did fairly well on Craigslist, found an original, not rotted out, not even slightly rusted, spoiler. granted I drove 500 miles to get it, but for $200 it was hard to pass up.
Old Feb 23, 2017 | 11:00 PM
thtanner's Avatar
Same here.
I'll replace it with a Hawks one when I do a full resto on the car in a few years time. I also have my original, in decent shape to be honest, maybe I can have it reworked.
Old May 6, 2017 | 10:58 PM
88Greg's Avatar
Car: 88 Trans am
Picked up a Hawks unit on sale. Here it is compared to the rotted stocker. Im pretty happy with the quality.
Maybe I should mount them stacked like that for some "Fast and Furious" style Biplane cred. Altho I think that only works on Hondas.
Attached Thumbnails Fiberglass 85-90 aero spoilers-20170506_151137.jpg   Fiberglass 85-90 aero spoilers-20170506_151201.jpg   Fiberglass 85-90 aero spoilers-20170506_151237.jpg   Fiberglass 85-90 aero spoilers-20170506_151247.jpg
Old May 8, 2017 | 09:14 PM
Good comparison photos 88Greg. Thanks.
Old May 9, 2017 | 07:20 AM
great comparison.
Nervous2
Firebirds Wanted
Mar 27, 2021 08:06 PM
Eric-86sc
Convertibles
29
Jun 8, 2020 10:16 AM
T_P_S
Jun 25, 2016 04:56 PM
Wingpower
Jun 4, 2016 07:19 PM
usafirebird
Mid-West Region
May 16, 2016 10:23 PM
